oil leak 455 back passenger side
I put dye and ran engine. there's small amount of oil coming down above the filter housing. i cant get a good where its from because of the tight space.
what do I look for.... distributer o ring? I dunno
thanks for the time in any reply
OIl leaks at the rear can be mis-leading. The dye in this case is helpful, but you'll need to get a good look soon.
Its usually the valve cover or the seal between the intake and block. It might be something else but concentrate your efforts there at first.
