oil leak 455 back passenger side
Old Apr 16, 2026 | 11:04 PM
blp's Avatar
blp
I put dye and ran engine. there's small amount of oil coming down above the filter housing. i cant get a good where its from because of the tight space.
what do I look for.... distributer o ring? I dunno
thanks for the time in any reply
Old Apr 17, 2026 | 03:59 AM
don71's Avatar
same but different
OIl leaks at the rear can be mis-leading. The dye in this case is helpful, but you'll need to get a good look soon.
Its usually the valve cover or the seal between the intake and block. It might be something else but concentrate your efforts there at first.
Old Apr 17, 2026 | 09:41 AM
blp's Avatar
blp
DON
ty very much... going to taske the deeper look this morning with a mirror....
79cut
Oct 31, 2025 03:46 PM
oldsrush
Mar 21, 2024 04:09 PM
blp
Aug 22, 2023 09:25 PM
brandon 455
Jul 10, 2013 06:09 PM
70 holiday coupe
May 31, 2011 08:02 PM
