How do I make my oil tube fit???
Old Jan 6, 2025 | 11:18 PM
sx455raidercelticfan's Avatar
Hi my original oil tube fits loose how do I make it fit?? I’ve tried hammering sockets through it!
thank you
Old Jan 7, 2025 | 03:58 AM
That's odd. Mine always fit too tight. I used to have a exhaust pipe expander that was made for when you wanted to use a muffler or whatever that had been deformed by a clamp. I wonder if you could expand it with one- or could a exhaust shop do it for you? Good luck!
Old Jan 7, 2025 | 05:44 AM
Run to Rund's Avatar
I re-use mine many times and use ultra black RTV to hold it in place.
Old Jan 7, 2025 | 06:15 AM
oddball's Avatar
Cut off a bit - 1/8" or so - from the bottom and test. Might need to cut twice. I've had to do that after removing the same tube several (~10?) times.
Old Jan 7, 2025 | 07:04 AM
They sell new/used exhaust pipe expanders should you be interested in owning. Harbor Freight carries them & select automotive supply chains. Here's a used one on eBay: Pittsburgh Tail Pipe Expander, 2-1/8 in. to 3-1/2 in. You might find others.
Old Jan 8, 2025 | 03:34 AM
Thanks guys I cut off around a half inch and whacked a socket through it it fits now!!!!
THANKS AGAIN
Old Jan 8, 2025 | 07:10 PM
FStanley's Avatar
Trivia
to take mine out, it got so dented up..
I straighted it out best I could using a small pipe inside held by a vise, then used lead to fill the small dents and filed it smooth again, like new after painting it..
Fred
McIntosh
May 4, 2020 06:41 AM
76cutlass
Jan 16, 2014 05:54 AM
rayfrausto
Jul 20, 2011 03:30 PM
ctrain22
Jul 29, 2009 10:46 AM
woodie582
Nov 10, 2008 06:48 PM
