Electrical terminals
Old Feb 25, 2026 | 01:23 PM
I知 building a new dash harness for my 455 powered 81 GMC. I知 trying to find a vender/part number for some of the less common terminals. I知 installing a factory style tach, adding Retained Accessory Power, and Theater lighting. So pretty much everything will be custom. I did this conversion on my 69 many years ago, it works well.
First, I need the terminals for the connector to the instrument cluster. I知 pretty sure it痴 the same terminal as used on the later G body cars with the clear plastic circuit board.
Im also looking for ATO fuse terminals in strips of 6.
I have tried Mousier, with zero luck.
I can find ATO fuse terminals in strips of 4, I need a couple with 5 and 6 in a strip.
Old Feb 25, 2026 | 01:49 PM
That dash connector is used in Squarebody trucks. Check the specialty vendors for those.
Old Feb 25, 2026 | 02:16 PM
If it's used in Chevy trucks check here.
https://www.lmctruck.com/
Old Feb 25, 2026 | 02:22 PM
dc2x4drvr's Avatar
Checkout this company, I have use their connectors for years.
https://ceautoelectricsupply.com
Old Feb 25, 2026 | 02:35 PM
442Dude's Avatar
How about these...they fit GM Printed Circuit Boards for clusters from 73-87.....
https://www.summitracing.com/parts/r...iABEgLBpfD_BwE
You may have to get the connector with the terminals but still pretty cheap if you need them.....
Old Feb 25, 2026 | 04:30 PM
fleming442's Avatar
JEM
Ballenger Motorsports
And, Kwik Wire should have them
Or, here: http://1973-1987 All Makes All Model...FFY7lyKF05TfKO
Generally speaking (pun intended), they should be either Packard or MetriPak.
matt69olds
May 29, 2020 07:51 PM
77ricbaez
Jun 29, 2017 01:16 PM
bwayco
Apr 15, 2017 09:37 AM
jwr7042
Aug 17, 2016 06:22 AM
65 starfire
Jan 13, 2009 05:13 PM
