Where on a 303 engine is an oil passage fitting
Old Jan 7, 2026 | 03:46 PM
Old5388's Avatar
I have a 53 Super 88 with a 303. Where can I find an oil passage for an oil pressure switch? I need to wire an oil pressure switch to an electrical fuel pump as a safety precaution. The internet said to wire it to the switch next to the oil filler tube. That is a coolant sensor/switch on my engine.
Thanks for any help.
Old Jan 7, 2026 | 08:44 PM
Charlie Jones's Avatar
Phantom Phixer
The oil pressure sender is at the right rear corner of the engine.
It screws in to the oil filter adapter.
The switch should be one that closes at least 10 PSI.
You will need an extra fitting so that both the oil pressure sender and the safety switch have oil pressure.
Old Jan 7, 2026 | 09:04 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I put one on the 54 I had. I also changed the oil filter adapter to one that used a spin on oil filter. It took a few fittings but it worked well. I did use a bypass switch to cut down on the cranking time.
Old Jan 8, 2026 | 05:47 PM
Old5388's Avatar
Charlie Jones.....Thanks a lot. I was really hoping someone could answer that question about where an oil pressure outlet is. I will jack the car up and check it out. That will work fine. Today I bypassed the mechanical fuel pump and the car ran just fine. So I removed the mechanical pump and installed a block off plate I had in my junk can from some other car. And I plugged the vacuum line from the base of the carburetor. This just gives me time to decide to either try to find a rebuilder who can rebuild my mechanical pump, or maybe install a small electrical vacuum pump under the car to run the wiper motors. Anyway, thanks a lot for the help. It is appreciated.
Old Jan 8, 2026 | 08:23 PM
Phantom Phixer
Fusick Automotive re-builds pumps.
Rebuilt fuel pump, 1949-54 Oldsmobile V8
I'm happy with the one they did for me.
Old Jan 15, 2026 | 07:05 AM
GLDN88's Avatar
Good morning, sorry to jump in on this late. If you're DIY inclined, I have had a great experience with Then and Now Automotive. They have kits or they can rebuild your unit. Here is a link to your kit: https://www.then-now-auto.com/produc...fuel-pump-kit/
If you want to call them, reach out to Lisa Pawlik - ljthen2@aol.com and she can be reached at 781-335-8860.
Good luck, David
mikespike
Feb 17, 2024 07:11 PM
carpenternotmechanic
Mar 24, 2021 07:56 PM
Hillbilllystarfire
Jun 15, 2017 09:56 PM
slade69
Mar 23, 2017 08:14 AM
jtriggy
Apr 8, 2010 07:45 AM
