Rotten water jacket
Old Jan 31, 2026 | 11:14 PM
GCH's Avatar
GCH
Rotten water jacket
CRC ThermoCure is an excellent flush. If the plan is to run water through the radiator while it is out, it is ineffective. At a minimum confirm that the factory light works.
Yes , ThermoCure works nice. Have had some heating issues in my 98 but not in the 88 .
Here is a pic from the 88 engine who is at the machineshop now. Plug between cyl 5 and 7.
And also crap in the hole the other side between 6 and 8. But no heating readings on the gauge.
Somebody in Californa have also removed the heat riser in the exhaust manifold.
Old Feb 1, 2026 | 03:00 AM
Did that freeze plug rust out?
My 64 98 had one of those heat riser valves in the exhaust manifold. It was seized partially closed so I knocked it out.
Old Feb 1, 2026 | 03:48 AM
GCH's Avatar
GCH
No the freeze plug did not rust out. I suspect
that it looks the same in the 98 engine. The heat
riser in the 98 work bad so i forced it open with
a wire. But should remove it when it can.
I should put a tempgauge in car before summer ,
the 88 have a mechanical gauge that works fine.
Old Feb 1, 2026 | 05:07 AM
I moved our posts so we didn't hijack the other thread.
As mentioned, don't fall down the temperature gauge rabbit hole. That being said, if you decide to go with an aftermarket gauge I have 3 AutoMeter gauges in my 86 Ford truck. They work great.
Old Feb 1, 2026 | 05:52 AM
GCH's Avatar
GCH
Ok Jesse , well the red light have come on a couple of times when we drive slow cruising but we have not done that for a while. I don't mind having a gauge in the car .
Have three SW gauges in the 88 and they work great.
eggydrummer
Apr 5, 2024 02:43 PM
Kellyann3570
Jun 14, 2023 12:29 PM
4R5
Jan 26, 2022 06:59 AM
olds88royalvert
Jun 11, 2011 04:29 PM
KQQLCAT
Nov 8, 2007 04:48 PM
