Parts Help Needed
Old Aug 29, 2025 | 12:32 PM
ajr2820's Avatar
Parts Help Needed
I am looking for the nut that holds the hood bumper to the cowl. I have the bumper and the screw, but not the nut that fits into the square hole. Must be some kind of captive nut. I can't seem to find it anywhere in my parts bags, so I must have lost it. I certainly would not have thrown it out.
Is there a supplier that carries these? I have searched with no luck.
Old Aug 29, 2025 | 06:00 PM
66SportCoupe's Avatar
Some hardware stores offer snap in captured nuts
Old Aug 29, 2025 | 06:32 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Crystal ball isnt working...Year make and model is always nice to zero in on what your workin on
https://www.mcmaster.com/products/nuts/snap-in-nuts-2~/
Old Aug 30, 2025 | 07:39 AM
ajr2820's Avatar
Yeah...duh! Sorry...1972 Cutlass Supreme.
Old Aug 30, 2025 | 09:26 AM
BillK's Avatar
Its probably a pretty standard GM part. Most likely the same that is on my Chevelle. You could try AMK. They have a lot of that type of stuff.
https://www.amkproducts.com/ I am going out in the garage after lunch. I will see if the Assembly Manual has a GM part number.
Old Aug 30, 2025 | 09:34 AM
ajr2820's Avatar
Thanks all. I ended up using a small square of sheetmetal larger than the square hole and installed a rivet nut. Seems to be solid.
JenR8r88
Apr 13, 2023 06:37 PM
kenb47
Nov 23, 2011 06:01 AM
kenb47
Nov 23, 2011 05:53 AM
KQQLCAT
Mar 28, 2008 10:14 AM
DATNFAMOUSRICAN
Nov 21, 2007 07:14 AM
