Need help PLS!! Identifying fuel lines
Old Jan 2, 2025 | 10:00 PM
sx455raidercelticfan's Avatar
Hi guys can someone please point me in the right direction, I don’t know which lines are which, I need to know what line is the fuel delivery line and what line is the return line, Also there’s a line with a weird crimp in it, Thank You
Old Jan 3, 2025 | 01:24 AM
I assume this is a 1970 with the evap cannister? The two lines that go through the front crossmember are main fuel line (large one) and fuel return (small one). The other line goes to the evap cannister. The "weird crimp" is the restriction in the evap line to prevent liquid from being pulled out. You are missing the vapor separator that bolts to the bottom of the floor pan. And the PIM is your friend. All of this is shown in Section 8.
Trivia point: note that this diagram says "exc. W27". There is a slight difference in hose routing on W27 cars to clear the cover.
Old Jan 3, 2025 | 02:34 AM
Joe thank you very much!! As all ways you’re the best!!
cdrod
Apr 15, 2019 02:36 PM
71cutlass350
Mar 27, 2018 09:21 PM
Oldssupreme
Jan 19, 2016 05:17 PM
olds408
May 4, 2014 02:19 AM
pcard
Apr 5, 2013 12:43 PM
