I have a questions about the routing of the capillary tubing for the expansion valve in a factory AC system. In pursuit of neatness, I wrapped the excess capillary tubing around the evaporator discharge line; this hides the extra tubing under the cork tacky tape. It seems most people just coil up the additional tubing. To be clear, I used the extra small tubing from the TXV to wrap the bulb against the evaporator tube. Will this affect cooling performance?
Rodney
Most guys just coil the extra capillary tubing - see green arrow.
I wrapped the extra TXV tubing around the bulb in a serpentine fashion.
