Expansion Valve Capillary Tube
Old Jul 9, 2025 | 12:02 PM
cdrod's Avatar
Rodney
I have a questions about the routing of the capillary tubing for the expansion valve in a factory AC system. In pursuit of neatness, I wrapped the excess capillary tubing around the evaporator discharge line; this hides the extra tubing under the cork tacky tape. It seems most people just coil up the additional tubing. To be clear, I used the extra small tubing from the TXV to wrap the bulb against the evaporator tube. Will this affect cooling performance?
Rodney
Most guys just coil the extra capillary tubing - see green arrow.
I wrapped the extra tubing around the bulb at the end of the TXV tubing in a serpentine fashion.
I wrapped the extra TXV tubing around the bulb in a serpentine fashion.
Old Jul 9, 2025 | 12:37 PM
I doubt it will make any difference. The bulb on the end of the tubing is where the temperature measurement is most critical.
Old Jul 9, 2025 | 02:23 PM
dc2x4drvr's Avatar
No difference as long as the tube isn’t crimped, too bad we can’t buy the OEM version..
Good luck on your build.
Bearddrywall
Mar 3, 2024 02:46 AM
timothypaul
Brakes/Hydraulic Systems
Mar 29, 2023 07:10 AM
jklmmorr
Oct 31, 2022 05:31 PM
redoldsman
Nov 18, 2020 06:17 AM
supmarjo
Jul 21, 2017 01:44 PM
