PCV Valve 67 330 Quadrajet
Old Jul 20, 2025 | 03:34 PM
Brosmobile67's Avatar
I am trying to remove and replace the PCV valve on my 67 Cutlass stock 330 V8 Quadrajet . The car has been in the family since 67 and generally all original. The current and likely original PCV on the passenger valve cover is brass colored with a bolt-like hex appearance. The replacements sold are typically round barrel shaped silver PCVs. Tugging on this PCV it doesn't seem to want to come out. Unscrewing it seems like maybe it backed out a bit as if threaded but then just spins.
Is there a nut or clip under the valve cover holding in place? How should this come out?
I don't want to remove the valve cover to inspect (it's a long story).
Old Jul 20, 2025 | 03:47 PM
442Harv's Avatar
Not a 67 expert, but I don't think that is stock. I would try prying the whole think out, the gourmet and all. May have to buy a new gourmet, to redo, and put a stock PVC valve back in.
Old Jul 20, 2025 | 03:57 PM
Before I got the pry out the grommet route. Do you have an idea how these are mounted? Is there a nut or a clip on the underside?
Old Jul 20, 2025 | 03:58 PM
Try some penetrating oil around it and get it to twist and pull out. That is not the stock pcv.
Old Jul 20, 2025 | 04:58 PM
With the hex I would think it has a threaded section that is screwed into the grommet. Try unscrewing it and see what happens.
Old Jul 20, 2025 | 06:17 PM
That's not the original PCV valve. The original valve simply slips into the grommet. The grommet gets hard with age, in addition to years of heat and varnish that can cause it to stick. Keep pulling.
Old Jul 20, 2025 | 08:29 PM
If you GOTTA know, pull the valve cover.
Old Jul 21, 2025 | 09:05 AM
Sugar Bear's Avatar
Also try turning it out, some of those aftermarket valves had threads that the rubber may have molded toward. Doubt there is a nut or clip. Order a new grommet, valve and hose before putting it apart as you'll probably need them. May also want to have a valve cover gasket on hand.
Old Jul 21, 2025 | 09:26 AM
Thank you Olds Wise Men. Will the stock valve cover of the 67 330 have a baffle under the PCV hole that will catch most of the potentially crumbling grommet? If not, I will take extra surgical precautions. I do not want to remove the valve cover as I sealed it with RTV about five years ago, which I partially regret, apart from zero oil on the manifolds. I can't remember what it looked like on the underside. The other side does have a baffle.
koops99
May 4, 2026 02:42 PM
Paul Judd
Feb 13, 2022 06:09 AM
68442
Dec 3, 2021 07:22 PM
Inline
Jan 15, 2020 04:19 AM
Almond900
Feb 26, 2016 02:56 AM
