View Full Version : Small Blocks
- Replacement fan shroud too small
- Breaking up, popping, and even shut down... Ignition.
- Crankshaft key question
- 83 307 problems
- distributor bolt hole question - 350
- New and need a little help
- 1981 Toronado Belts
- Olds 350 Exhaust cross over port in intake
- Last 403 built at the factory
- rubber vs. cork
- 1973 350 timing
- Timing set, new problem
- Headers
- 307 Rebuild
- 330 heads
- Porting stock 350 manifolds?
- PCV Valve troubles
- Intake/ seeping oil leak
- 330 4v Harmonic Balancer vs. early 400/425
- Distributor Hold Down Bolt
- RPM performer hood clearance '71
- Mobil 1 M1-206 or Fram Ultra Synthetic 3506?
- I Need Help! New Waterpump on 72 S 350. Now Belts Won't Line Up
- Torqued off!
- Cooling my 70S with the 350 upgrade
- Fuel pump question
- Shimming oil pump psi spring?
- shaking my head
- New Distributor for 1970 cutlass 350, recomendations?
- olds 307
- stutter, hesitation, under load only
- 69 rad cap
- Intake Manifold - All in one posting (hopefully)
- What is it called???
- HELP!!! no fuel going to carb and im stranded!!!
- Cam for 1970 350 #6 heads
- Who wants to beat this dead horse?
- how do you tell what heads they are? how do you know if they need to be worked on?
- distributor ?
- Camshaft play
- 350 heads
- Lifting my 330
- Rebuild kit?!
- Rochester 4 Jet carburetor model ??
- Cylinder head bolt question
- 403 to replace 350?
- Gasket for oil pressure sending switch
- Tick tick tick
- overbore only DX SBO Olds build
- Who rebuilds CCC quadrajets?
- carb help 725 demon road master
- Cam timing
- What's that sound?
- two piece intake gasket vs. Valley pan intake gasket
- motor building advice
- Engine dies when put it in drive
- Pushrod geometry question...
- Flow Numbers
- Quadrajet problems
- wood spacers vs. aluminum spacers
- Help ID these please
- valve cover Breather size?
- Which pistons 14cc / 23cc ?
- Rocket 324 troubles
- Hard start after sitting for 2 weeks or more...
- Thinking about a new carb!
- edelbrock carb problems
- Engine turns over slowly
- intake help
- 1971 #7 Head Valve Spring Pad & Rotator Question
- Carburetor Help
- Fuel pump variation - glass bowl vs all metal housing
- Another Head Question
- 3a heads vs 7a heads
- Lower radiator hose rubbing - '72 Cutlass
- 67 330 intake gaskets
- Pictures of engine and engine bay
- Help with rocker studs
- best rearend gears to replace my stock gears
- Smell of Gas under Medium/Hard Acceleration
- 71 350 rebuild help needed
- Share your 350 rocket exhaust experiences
- 65 Cutlass + exhaust manifold ?
- Removing 350
- HEI Ignition
- looking for air cleaner options/ pictures of setups.
- What is a 1972 running 350 rocket with 47,000 original miles worth
- 350 intake gasket
- Why in the hell are certain parts restricted?
- Rocker Arm Studs
- Timing Recurve Kit Question - Hopefully before sundown
- EFI or Q-Jet?
- 403/350 heads dyno results
- Exhaust Questions
- Installing #5 Heads with Studs
- Steel vs Cast Iron Distributer Gear
- gathering information
- 1989 Olds 307 engine
- Was there such a thing as factory installed dual pcv valves?
- Starting concern.
- Oil ring question
- Changing Carburetor
- 1966 Cutlass Ultra High Compression Air Cleaner
- Engine Install
- 69 olds
- Quadrajet Jet and metering rod recommendations
- I need more power and i need it now!
- 69 350 with 5a heads
- Olds 350 with #8 head
- Missing ERG Valve? 71 Olds 350
- Sanderson Headers for 350
- 1977 350 help
- Anyone have experience with this vendor?
- MSD Module died
- Fueling issues?
- Starting issues and oil leaks
- Dyno or Synthetic
- Polishing chambers on #6 heads
- Looks pretty good for a 260
- Three dead cylinders puzzle
- Aftermarket timing cover ?
- W-31 head gasket question
- Replacement radiator 68 Cutlass S
- 303 Valve Stem Seals?
- DVCS questions
- Distributor question
- Bar Stop Leak
- Identifying a cam
- 1954/55/56 starter
- Blowby issues
- 295 hp 350?
- *****help****
- Timing gear removal
- Converting from single to dual exhaust
- Testing your HEI
- Which intake for 67 330
- Lucky 350 find?
- Intake runner lengths and sizes?
- oil pressure light flashing during break in
- No oil pressure after warming up
- Overheating for some reason
- Now I'm just confused
- Rocket 350 Build (long)
- 67 330 engine differences
- One step closer
- Ryan Weaver 1969 W-31 350 SBO engine build
- silhouette 3400
- hp
- 403 stroker build questions
- Quadrajet rebuild
- 403 with 350 heads what a difference!
- 1983 hurstolds 307
- Roller rocker mount
- 1972 350 bracket bolts.
- back pressure???
- 1970 350 4 speed w/AC; 393859 cam?
- build a 350
- High Idle Speed
- Compression test question -rocket 350
- what is Oldsmobile 350R motor
- Anyone know Holley 4160s????
- what are you guys using for ignition wire looms?
- olds valve cover breather
- Newb with a few 1971 questions, thanks for the help in advance
- Cam advice
- Newb with a few ingition/carb problems on 69 cutlass
- When to do compression testing
- help identifying these parts
- Need help to I.D. my motor
- 1964 Cutlass with a 1971 350 in it.
- Correct AC delco oil filter for 70 w-31
- Olds 307 swap advice
- Automatic choke on 2 bbl carb
- Quadrajet base leak
- Valve cover gromet for pcv valve in moroso standard height valve cover
- 1969 Cutlass S 350 2 brl intake manifold
- Oldsmobile 307 engine in 1989 Cadillac Brougham
- 371 J2 engine - bent rod - any ideas??
- Dipstick length
- 56 heads
- SBO Help
- Carb Question
- Best Header Selection for a '76 Cutlass Supreme
- What ignition coil.to use for stock 350?
- 4/7 swap
- engine not completely shutting down immediately
- SBO Intake options
- Exhaust leak or collapsed lifter? An annoying ticking noise.
- 215 coffee table?
- need tuning help
- Rocker Arms not straight
- Engine Decoding Help
- 1970 Oldsmobile Delta 88 350 no power won't start
- Dang Engine started Knocking
- Engine is extremely rough when starting in the morning
- Engine takes over a minute to start, no fuel visible in the filter
- Engine mounts
- New to the site and looking for some cam advice
- 350 stock manifold vacuum ports
- Piston Dome
- Cam Suggestions
- #8 Heads on a 350
- 330 Rebuild or Replace
- mixing up 350s
- Power Steering Pump Bracket
- Guideplate advice
- Gas in oil- 350 Rocket
- push rod probs
- Reusing old gasket is it possible...
- Oil filler tube question
- Cold air intake
- 215 cubic inch Rochester 4GC Stock Jet Sizes
- 403 rocker bridge
- Engine won't start
- Anyone recognize this harmonic balancer?
- 1984 Olds 307 running rough on startup
- Dick Miller Serpentine Pulley Review
- 350 plastic in the oil pan????
- 350 build advice needed
- 1987 cadillac olds 307 upgrades?
- 350 build questions
- Timing Concern- set high at idle
- 1979 oldsmobile delta 88, 350 "rocket" valve cover gaskets?
- Still ticking after valve adjustment
- 307 to 350
- 74 88 HEI hook up???
- Open element air filter
- Cam Profile for 350 Dual Quad Set Up
- Experience with Jet Performance Modified Quadrajets
- 1972 350 Engine Problem
- Show us your pulleys!
- RPM hood clearance
- 303 Lives
- 1970 Delta 88 Engine Compartment Stuff
- Choosing the right headers+starter: '72 Cutlass Supreme
- crankshaft pulley
- gasket advisory
- Front cover install trick
- Measuring piston to deck
- 350 olds
- 303 Points to HEI?
- distributor hold down
- The Number One Cause Of Reman Engine Failure butWith A Bullet
- Rocket 303
- 1975 olds 350 engine build
- 70 350 Cam Recommendation
- So moving on, what is a good HEI set up?
- 66 330 ignition issue?
- Need Help
- Tips for 10 hole valve covers on a 5 hole head
