Measuring piston to deck
On the edges, which are the tallest parts of the pistons. Find TDC, then use a dial indicator or put a straight edge across the bore and use a feeler gauge to determine the clearance. Do all 4 corners
Thanks I'm using the feeler gauge method and it measured .020 in the bore. Just wanted to make sure I was doing it right
