- Engine Advice For Vista Cruiser
- Separating pulley from harmonic balancer
- 1979 Olds 98 LS: cooling issue
- Oil pump pressure release valve
- 57-58 to 59-60 Fuel Pump interchangeability?
- Intake valves not seating
- 1955 Oldsmobile rear main seal
- 78/79 350 Headers ???
- Camshaft recommendation
- Electric Fuel Pump
- 67 330 block ID
- 350 Cam installation
- What water pump do I need?
- Oil squirters
- Cam in 307 Olds
- Heater core Replacement
- 1967 CS Accelerator cable with Switch Pitch Jetaway
- Rebuild an Olds 350 -395558-2 Engine with 7 Heads
- 71 CS, Power Steering Question
- Cam lobe/lifter alignment
- Engine Build: 434ci SBO 350 built by Mark R.
- Overdrive Alt. Pulley SBO 350
- Connecting rod bolts
- Power Steering Belt cracked
- I'm back. 350 pushing out coolant
- 324 Olds oil dipstick?
- Engine to the Machine Shop
- New rear main seal in the 403.
- 350 oiling
- 307 or 403?
- Thornton Exhaust Manifolds
- Update on Q-jet leaking down after sitting for a week
- Aftermarket Fuel injection question
- New Flexplate for 1958 Olds 88 with orginal 371 and Hydramatic?
- 403:basic power-kit to upgrade+keep reliability?
- OAI fiberglass hood insulation
- Interference
- Water pump bolts
- Project Cheap A$$ DX
- 1971 Cutlass 350 Rocket
- Is this a decent block for a street build?
- Still Major Overheating since 2017! Timing OK?
- 1975 Q-Jet Aux. Power Piston &Rod
- Throttle Return Spring_1968 Olds Quadrajet 4bbl
- Cam Timing Fun
- Vacuum idea
- 1968 350 250hp rebuild to higher compression engine
- misfire while in gear
- Changing valve seals
- Restoring and Painting Cast Iron Intake Manifold
- Camshaft Identifcation - Sealed Power?
- Long tube headers for a 71 Cutlass Supreme 350
- 330 offset ground balance question in a 403 block?
- Is this bearing still usable?
- 1978 SBO somehow different than others?
- Stud/guideplate question this time
- Best Cam for Daily Driver 350
- Comp Cams XE262H or Lunati 262 With Stock Springs?
- 403 Block with 350 crank?
- Freshly Rebuilt 1958 Olds 371 Knocking at Idle
- Performer RPM intake
- Head gasket for 350 olds
- 1987 442 307 EGR Vacuum Chamber leaks.
- Torque And Sequences
- 403 Intake manifold
- Olds 307 cooling
- Nr.1 main bearing drilling on block
- Winter work....
- another another header question
- Fuel Plumbing - Ideas
- Has anyone converted a 307 to EFI?
- 350 Mostly Stock Rebuild
- Olds 350 Rocket oil pressure issue
- Looking for 350.30 1 1/8 inch oil ring set
- Engine #s help identifying please
- 350 Stock Small Oil Leak
- Engine Help/Question
- Iron head max lift, stock length valve guides
- Motor Mount Heat Shields & Headers?
- 76 350 cam?
- 371 Oil Pressure issue
- 330 hp ratings ? 315 hp fact or fiction ?
- Engine Temp - Operating Range
- Intake Leak?
- HEI distributor instead of points/condenser!
- Craftsman beam type torque wrench on bearing caps?
- C headed 403 Build
- Number 5 heads - replacement valves
- Oil slinger issue
- R44SX vs R45S for SBO 330ci HC ?
- Installing HEI Dist.
- Bigger valves on 7A heads
- ID this exhaust manifold
- New Exhaust - 434ci Olds 350 Build!
- Fitting Dual Exhaust to my 1966 330
- First Cold Weather Season - Tips
- 96 3.1 ciera.
- Distributor and coil numbers
- lumpy idle on 1978 Olds Delta 88
- What Engine do I have?
- I need more timing!?!?
- Holley 4150 on Stock Manifold
- Distrib Vacuum Control Switch QUESTION
- Align hone after replacing main bolts?
- Spark Plugs-Tapered???
- Oldsmobile 257 engine stuck
- OBD1 Scan Tool?
- Setting Up the ILC?
- stock 403 w/ #7 heads
- 403 w/ 350 heads - Large or Small valves ?
- Building 72 CS 350 motor
- Headers
- Bearing Clearances
- Chipped main bearing
- Speed FX HEI Distributor
- 350 piston/ring failure
- Starter wire heat shield bolts
- Air Cleaner Vacuum Pieces
- New I beam Rods
- Fuel lines for 72 CS
- 1970 Olds 350 from a Cutlass S
- Rebuilder Recommendations - 330 in AZ
- 1985 Monte Carlo SS
- Compression Test Result Questions 1972 350
- Dual throttle spring for Olds Rochester 4bbl
- coincidental points issues?
- RHD conversion throttle cable routing
- 350 build
- 67 VC Exhaust Leak
- '68-'70 350, looking to convert pulleys to serpentine system
- Linkage and carb question
- Fuel Line
- Throttle question
- spark plub wiring for HEI on a 65 330
- 350 exhaust manifolds
- Rust on crankshaft journal
- Timing a 76 cutlass
- 1971 350 water pump
- power steering pump bleeding procedure 1972 cutlass
- Belt tightening procedure and method
- Core support/radiator/air deflector questions 1972 Supreme
- What to use for a rear main seal in Olds 350
- Finding TDC....
- Intake Manifold
- Looking for crate engine recommendations
- I'm in
- Valve seals (little upset with shop)
- Vacuum/Timing
- Check Engine: Need Help with Some Codes
- Engine overheating or Busted temp. guage?
- Lets play another round of Identify That Part
- Oldsmobile valves ( 350)
- High frequency noise
- 1971 Cutlass Fuel Line
- Car seems to idle fine; sputters in gear
- Machine Shop for SBO stroker in Eastern MI
- Rear Main Seal
- 1970 Cutlass Cruiser exhaust.
- Installing temp,oil psi and volt meter
- 350 twin exhaust system
- 1971 Cutlass 350 timing
- EFI’d SB Stroker build
- Identifying harmonic balancer
- '69 Cutlass S
- A/C belt tension?
- 307 Electric Fuel Pump installation
- Problem With Main Caps...
- Correct Hone grit
- Cam Recommendation
- edelbrock 1406 carburetor
- '77 Cutlass Thermostat Housing
- Headers
- ARP main bolts
- Harmonic balancer center bolt direction
- Mini starter making screeching sound in gear
- 69 Cutlass S Convertible -- sluggish, no power
- 7A Head Work?
- What type of firewall grommet should I be looking for?
- Low manifold vacuum on 350 indicating likely valve issue, where to start?
- 330 Max Overbore or Min Cyl. Wall
- Timing cover sealing after timing chain replacement
- Distributor and Vacuum port....
- Gas in brake booster??
- 72 olds 350 rebuild help
- Flat Tappet vs. Hydraulic lifters...correct oil?
- 65 330 4v swaping to 1970 350 4v
- 70' 350 specs/tolerances
- 303 Exhaust Manifold Bolts or Studs?
- What is the oil tank capacity for a 1970 rocket 350?
- Installing Edelbrock 3711
- 1967 CS Holiday Coupe - 330 Oil Pressure Sensor
- New Edelbrock Intake
- 1964 F85 exhaust down pipes.
- My Engine Rebuild
- Rebuild the 330 or swap to 350 Chevy??
- Pulleys Unaligned Rocket 350
- To RTV or To Not RTV?
- Intake manifold
- Oil Filter for 72 350
- Q-jet woes E4me - hiccup/flat spot
- eBay Engine Rebuild
- edelbrock 1403 reveiw
- Is it truly necessary to have an EGR valve or PCV?
- Dwell angle changed??
- Overheating or bad idiot light sensor?
- My Olds build!
- Cylinder numbering at distributor
- My Daughter to my 70S for a small drive
- Compression guess
- 72 350 won't stay running
- 1971 350 4 barrel carb question
- Head work
- Need cooling advice
- Elimination of CCC, computer, etc.. Edelbrock intake/carb
- Cam gone bad?
- What can i do to wake up my 350 ?
- Fan Clutch
- 1972 350 Rocket Help
- Charcoal Canister
- Recommended Shops in VA
- E4MC QJet ..broken parts and issues
- Conflicting engine information
- 330 exhaust manifold
- Can I mix "steel" exhaust valves with SS
- What does a stock cast iron 350 4bbl intake manifold weigh??
- Chart/specs for flow on SBO heads
- 1970 350 Initial/Cold Startup Question
- 330 heads on 403
- 403 help please
- 63 F85 Throttle Linkage
- 330 questions
- freez plug size.
- Rebuild or Replace the Rocket 350?
- Anyone have a match and a lot of gas!
- Computer CCC Carb issues on 83 Olds 307.
- Project 350 build/It's finally done
- Looking for pics of 350 engine
- 84 Hurst/Olds Cutlass Carburetor, any differences?
- 71 cutlass 350 belts
- Clearance issues using 7/16 studs on iron #6 heads
- Power Steering Question - Hose
- Lackluster performance from my 350
- 1989 Custom Cruiser engine is pinging
- Olds 350 rebuild let me kno what you see and whst I should replace to get up and run
- CCC Distributor
- Which efi kit should i buy
- 1966 Cutlass Manual transthrottle linkage
- What is this bracket?
- Milling the heads or thinner gaskets?
- 70’ 350 A/C Bracket Alternatives
