What water pump do I need?
Old Mar 6, 2019 | 07:34 PM
user 7408240824's Avatar
I have a 1968-70 350 5.7 block, no A/C or heat, what does the hub height of my water pump need to be? Thanks!
Old Mar 7, 2019 | 07:19 AM
don71's Avatar
same but different
This depends on what pulleys you are using. Each pulley should have a two letter code stamped on them. Knowing that, its possible to give you an idea.
I presume you don't have the old water pump to compare to?
Old Mar 7, 2019 | 07:21 AM
Whichever one matches the pulleys and accessory brackets you plan to use.
Sorry, but your question cannot be answered without more info. The pump length needs to match the pulleys and brackets. Any 1964-1990 Olds water pump bolts to any 1964-1990 Olds block.
Old Mar 7, 2019 | 08:52 AM
FStanley's Avatar
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
Old Mar 7, 2019 | 12:33 PM
76olds's Avatar
Hookers under Hood
The length of water pump may also depend on what type of fan you are going to use, you may need a spacer. Depends on what shroud you have as well.
As others mentioned, need more info here.
Eric
Old Mar 7, 2019 | 12:44 PM
No, it really doesn't. On an Olds, the pump length MUST match the pulleys and brackets, period. Once you get that to work, THEN you pick the correct fan and (if necessary) spacer.
Old Mar 10, 2019 | 05:23 PM
I do have the old water pump, it is a 6" hub height which I was told was only for with A/C (I do not have A/C). Without A/C is shorter although I do not know the exact hub height (I was told either 5 1/8" or 5 5/8"....although how could there be two different options when the rest of the pulleys are fixed in place?)...anyway, here are the castings from my pulleys:
Water pump - KE (there is also a P on the other side of the front face)
Crank - KS (same deal with the P)
Power Steering - KA
Did not see a casting on the alternator wheel
Also, I've attached pictures of the alternator and Power steering brackets that I am currently using, and pictures of ones that I found might actually be the right ones but cannot confirm for sure (the caption applies to the picture above it):
Alternator: might be the right one
Alternator: currently using
Powering steering: currently using
Power steering (1) : might be the right one
Powering steering (2): might be the right one
Thank you!!!!
Old Mar 20, 2019 | 07:15 PM
Anyone able to help me out based on the info I gave?
Old Mar 20, 2019 | 08:28 PM
RetroRanger's Avatar
72 Olds CS
I cant but im sure someone can.
If you have the old water pump and its 6inches why not get a 6 inch pump? or is there some other changes or new to you parts involved?
Old Mar 21, 2019 | 04:45 PM
72 Olds CS
ok i reread it and same question applies you had a 6" pump if it worked why change you make no mention of misalignment or other problems only that you heard 6" = AC. IDK if thats true.
Im only going on info you've provided and trying to help you out
I guess you could mock up all your pulleys and measure out from the timing cover and see what fits ?
nwcajun
Feb 6, 2023 10:51 PM
Dave Siltman
Jul 13, 2014 01:27 PM
tomc5
Jan 23, 2014 08:00 PM
1968_Post
Sep 13, 2013 06:29 AM
Finn5033
May 16, 2013 03:25 AM
