View Full Version : Small Blocks
- Fuel pump 307 dead?
- Installation fan controller
- What lifters do I use?
- 350 Rocket Power Issue
- Which 350 Valley Pan Gasket '72 and Below 7 heads?
- Cam selection
- Looking for pic of engine painted with Super Cars Unlimited Blue
- Whats this, & what do I do about it (if anything)?
- What motor is this?
- Olds 350
- short waterpump non AC 71- cutlass 350
- Need part number help. 1966 330 CI/HC
- White smoke or gaz out of carburetor
- Alternator pulley not lining up with crank and power steering pullies
- Idle RPM drop / carb tune
- Head Gasket 67 330
- Vacuum Diagram and parts identification
- Sticking Fast Idle?
- Mistakenly Bought Diesel Motor Oil for Gas Engine
- Installing HEI dustributor on 307 with photos
- 1966 330cui Rocker arm bolts
- Measure push rod lenght on stock rocker arm design
- Cleaning EGR passages
- Home made Oldsmobile motor mount straps
- Mechanical Temp Gauge Problems
- Stock Camshafts?
- 1984 307 misfireing
- 303 Front Crankshaft Seal
- 72 442 engine 350 4 barrel engine code L34
- Quick Help needed!
- Q-JET or 1405
- Engine Oil Fill Tube
- Flowmaster 17107 exhaust system
- fuel pump p/n for 83 vin 9 307 ??
- Mondello Heads
- Engle Cams
- XE 276 HR - anyone running it?
- 71 Cutlass Fuel Line/System Question
- Rally 350 engine specs??
- Alternator and power steering brackets, 1972 cutlass 350,
- 1970 Cutlass Supreme 350 Coolant Overflow Tank
- Engine Oil Recommendations
- in search of, olds engine builder
- Pic request of Stock 66-67 Cutlass 330 oil pan out of car
- Fuel Line Setup - Holley Carb
- Carb question
- Machine Shops
- 71 choke???
- Oil slinger ?
- Distributor advance - MSD Ready-to-Run
- Hooker Header Install
- 324 Rocket Problem Lifter
- Fuel Pump testing
- scratched cylinders...do they need bored
- Torque converter?
- 403 oil in coolant
- 330 Dyno Results
- Engine torque values
- Engine block number
- Carb Advice - Edelbrock Intake
- Decoding Olds 350 block. - pad reads EX73E244
- Engine code questions - 72 Cutlass 350
- Cylinder head large valves
- how do i tilt A/C Compressor
- summit racing 600cfm vs reveiw
- Radiator Recommendations
- Computer control or vacuum
- 71 Olds 350 Electric Cooling Fan Switch Recommendation
- Vacuum Advance?
- Need help coolant everywhere!!!
- Stripped intake manifold
- OLDS 371 1957 Oil Filter relocation & HEI
- replacing lifters
- Rebuilding 350 - I'm in a pinch
- HEI distr. repair parts ( pins)
- 330 or 455
- Pistons
- Qjet rear vacuum port question
- pace car
- Putting a cam back in
- Idle
- rebuilt 403 blue exhaust smoke
- 72 Cutlass 350 woes & input needed
- 350 300-350hp recipe ?
- wrapping up a really old build.
- Balancer specs
- Speedpro 350 forged piston weight?
- 350 head bolt/stud question
- 1988 Oldsmobile custom cruiser Olds 307 to 350 Engine swap
- Polishing combustion chambers, adding CC, any areas to avoid?
- Performer, or Performer RPM. THAT is the question
- Rear Main Seal - Blue Devil Sealer
- What should I do to my 350 while it's out
- Painting 350 heads
- Engine acts up after losing coolant; what should I be looking for?
- Oldsmobile DX block
- Timing chain replacement
- Typical Cranking PSI on 68-70 L74 (10.25) stock auto
- 324 coolant plug under heades
- Sealant on water pump bolts
- Roller set-up
- swapping from a 350 th400 to a 455 5 speed
- Wondering if I should get a Heady Duty Core Support or a regular one. 71 Cutlass S
- exhaust manifold
- Quadrajet or Summit carb?
- Diagnose my 350 engine?
- 403 Olds Alternator + Power Steering Bracket arrangement (Firebird)
- Fuel problem
- Small block 64 330
- HEI distributor assembly
- New Small Block rods
- Ignition coil replacment cutlass 1974
- Chamber size
- Bracket mounts for 1970 Oldsmobile cutlass supreme
- 1972 350 olds street demon 625 reveiw
- Header-CatConv Slip Joint?
- H pipe on an Olds 260 with dual exhaust?
- new member with diesel jeep questions
- rebuild of my rocket 350
- 403 Torque plate?
- Power steering leak 77 cutlass 350
- 67 330 HC Quadrajet idle
- Refill Accel Super Coil???
- Say I want to convert to a roller cam...
- Pulleys and brackets Need help Please
- 1"-20 fuel Inlet fitting what size
- 73 350 crankshaft cap bolt loose
- Intake for 350
- Correct Casting # for 72 Rochester ?
- H Beam rod
- QJet Electric Choke Conversion
- RPM manifold and factory OAI?
- olds 350 diesel to gas conversion
- Headers for a 1977 Cutlass w/350 Olds Engine
- 403 head gaskets
- Best halo style girdle for a 403?
- Oil Filler Tube - correct color?
- Quadrajet identification
- Power steering brackets 70 350
- Why Major Overheating Issue?
- Heater control valve
- 1964 330
- Edelbrock E-Street EFI
- New Member who got a gift and wants to fix some things
- Anyone running these headers?
- Oldsmobile 350 Sticker on Air Breather Cover
- 68-77 vs 77-80 350 olds rebuild kits
- Vacuum Switch / Sensor help
- Exhaust manifold block off cap / plate
- Header question for my 77 Cutlass 350
- 350 cam options
- Looking for Christopher from Performace 307
- Crankshaft 303 partnumber
- Just to say thank you ALL very much.
- Timing marks ?
- Olds 307 won't start, hard to crank
- Distributor shaft
- Just swap regular cast pistons for hypereutectic?
- New 350 build
- 355 Build Idea
- radiator question
- 350 Vacuum routing?
- 350 budget build for a disco era Skylark * Nova? Omega ! Ventura %
- 1954 Super 88 324 heads
- 350 Head Gasket Replacement
- Water neck to water pump hose 1972 olds 350
- Engine stud question
- I need a better fan
- 374 Stroker build
- Olds 307 no spark
- Posting Videos engine stalls
- #1 heads?
- Block cast id doesn't match stamped id
- Quadrajet questions
- 330 rod width?
- Distributor question
- New 350, 400E, 425 Pistons
- Edelbrock 600 has a whistle
- 1967 330 2bbl. questions.
- Approx. Horsepower?
- Distributor
- SBO heads does it matter
- Pistons
- 1954 Super 88 324 piston rings.
- 350 HEI spark plugs
- Valve Train Noise : I know...
- Correct Rochester 4 barrel gasket to use?
- Gains from Performer RPM intake amd 1.72 full roller rockers?
- 330 exhaust heat riser valve
- Snapped throttle cable
- 330 crank breather canister
- 350 gremlin
- Pre heater parts?
- 330 down on power and pressure at tank
- Other threads had me curious of my Olds 350 output?
- '69 350 teardown
- Approximate timing?
- 72 350 Build
- Hard start/sputter
- Rocker arms
- Belt Squeal...
- 307 engine
- Cylinder head delima
- Problem after problem.
- idle air control valve 84 cutlass 3.8L
- 68 350 2 barrell choke adjustment
- Mounting Engine
- 1987 Olds 307 Vacuum Hose Connections Videos!
- Oil pressure take off
- 77 olds 350 smog crap removal, track car
- Olds 307 - sludge
- 330 "chugging"
- 330 questions
- Low Compression 350
- Where does this A I R check valve go?
- 84 Cutlass Calais vacuum help mixed diagrams/engines 3.8 3800 231 v6
- Anyone using Crane link bar Hydraulic Roller Lifters in a 307 ?
- Tuning Rochester 4MV Quadrjet 4-barrel
- 65 330 Overheating issues
- stroker vs aluminuim heads
- Thermal Vakuum Switch (T.V.S.)
- 68 vs 69 olds 350 spark plugs
- 403 alternator and AC
- 84 Cutlass Cailas 3.8l v6 -- advice please
- '64 330 power steering brackets
- Edelbrock 7111 intake question on a olds 350.
- Overheating my 65
- Olds 350 strange knock #1 cylinder
- engine failure on olds 350
- Edelbrock 1904 Issue Making Me Mad
- Timing 350 Points Distributor
- New Valve Train
- Clack...clack 350 alloy heads
- 403 Excess Oil Consumption
- 330 Electronic ignition
- Intake and Vacuum Concerns
- Exhaust Query
- Which base gasket do I use for 2 BBL carburetor,(2 available)
- QJet Base Gasket
- Cam for 1977 350 stock valvetrain
- water pump
- Timing/Idle/Rebuild.....Help Please
- Possible pulley and water pump mismatch
- Will not start
- Bearings and parts
- fuel/air adjust with vacuum gauge does not work
- New Rochester Quadrajet
- 307, no fuel on a cold start
- 350 Pulleys
- Intermittent Code 21
