Quick Help needed!
Old Mar 30, 2018 | 08:39 AM
Sampson's Avatar
Quick Help needed!
Hey guys, can anyone help me pretty quickly. I am putting the front timing cover back on my 350. It did not have a oil slinger when I disassembled it. I bought one on line that turned out to be wrong. I filed the crank hole larger for it to fit. When I try to install the cover with the slinger the way I think it should go the timing cover will not fit to the block. This is Pic 1. If I turn the slinger around the timing cover fits. Pic 2. The pic in the FSM is not very clear. Does it go like pic 1 or pic 2.
There is a member on here who has the correct NOS piece but I would like to put this together today if possible.
Pic 1
Pic 2
Old Mar 30, 2018 | 09:18 AM
A picture from the web:
And another that indicates the slinger you have is not the correct one, which is likely why you're having issues with installation:
Old Mar 30, 2018 | 09:59 AM
Sampson's Avatar
Thanks Jim,
Better for me to slow down and get the right thing, than try to make something work. I have a local engine builder looking through his stash of Olds stuff to see if he has something laying around.
Old Mar 30, 2018 | 10:11 AM
Rustbucket2's Avatar
I see you have a double roller timing chain, Is the double wider then a single ?
Old Mar 30, 2018 | 02:56 PM
I have a double roller on my engine and it didn't cause any issues with the oil slinger.
Old Mar 30, 2018 | 02:58 PM
I didn't know if that makes a difference , I just noticed it, and thought maybe !
Old Mar 30, 2018 | 07:32 PM
Sampson's Avatar
Thanks for the replys and help. I decided to slow down and get the right thing. Even though it was close to 80 deg. Here today and I would rather be cruisin'
J-(Chicago)
Feb 9, 2012 02:17 PM
70_CS
Mar 23, 2009 03:32 PM
old.n.bold
16
Mar 10, 2009 07:43 AM
Jolly Green
Apr 2, 2008 01:04 PM
dallas6778
Nov 29, 2007 01:35 PM
