replacing lifters
Old Feb 23, 2018 | 09:24 PM
mother$hip89's Avatar
replacing lifters
While taking my engine apart, I had a lifter that put up a fight and ended up a little marked up towards the top. Can I replace 1 lifter or am I gong to need to replace all of them?
Old Feb 24, 2018 | 02:48 AM
You can replace just 1.
Old Feb 24, 2018 | 03:44 AM
m371961's Avatar
Assuming you put them back where they were if the engine was ran, and they have no excessive wear.
Old Feb 24, 2018 | 04:23 AM
jcdynamic88's Avatar
if that lifter is marked up from trying to remove it i would take a hard look at the bottom of that lifter.if 15 came right out and one was difficult there could be some wear at the bottom of the one that came out hard.if that's the case there has to be damage to that cam lobe
Old Feb 24, 2018 | 06:32 AM
This is possible, but more likely is varnish build up on the exposed end of the lifter. Next time, use the correct lifter extraction tool to avoid damage.
Old Feb 24, 2018 | 07:42 AM
Does the bottom of the lifter show wear, it will look concave. If so then you need to inspect all the others and the cam lobes.
Old Feb 24, 2018 | 07:55 AM
only varnish on one lifter? not likely
Mr. King
Aug 3, 2015 07:32 PM
67Olds442X2
Apr 13, 2012 08:42 PM
TennesseeDelta
Mar 27, 2007 02:01 PM
Mr. King
Feb 24, 2007 07:54 AM
