Approximate timing?
Old Sep 16, 2017 | 04:31 AM
Platinum69's Avatar
Approximate timing?
Hi, can anyone tell me the approx. Timing on my 73 350 olds with #5 heads, .472 lift crane cam, eldebrock performer, carb spacer 1", 600cfm holley, everthing else stock. Thanks
Old Sep 16, 2017 | 04:43 AM
Read these, I know its for a Chevy but Olds engines work basically the same way other than our dist turn CCW :
http://www.corvette-restoration.com/...ine_Timing.pdf
http://www.metroli.org/pdf/WHITE%20P...0Operation.pdf
Old Sep 16, 2017 | 05:23 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have found Olds, the low compression version, assuming your motor is around 8.5 to 1 with Felpro replacement head gaskets, like a lot of part throttle timing. If it is the points distributor, run around 14 base and 22 with the HEI. Also run full vacuum advance off the manifold. You can try one of the advance kits, I always use their lighter springs with the stock weights.
Old Sep 16, 2017 | 06:31 AM
The short answer is no. The correct initial timing for your motor depends on the application, the fuel you are using, the amount of carbon buildup in the chambers, the jetting, the gears, the altitude, the trans, the specific settings in the distributor, the exact CR in the motor, the exact valve event timing, etc, etc. The car knows far better than any of us what it wants for initial timing. Keep advancing the initial timing until the engine pings under acceleration then back off a degree or two.
jxnslotcar
Jul 30, 2015 08:58 AM
jpc647
Jun 10, 2013 11:48 AM
chrisneu68olds
Oct 17, 2012 08:51 PM
442scotty
May 13, 2009 05:42 PM
<Tim>
Jul 17, 2003 05:06 AM
