View Full Version : Small Blocks
- Cutting off old exhaust
- 380 build questions
- Dual exhaust coming off crossover manifolds?
- 61 f85 3.5
- Valve stem seal question
- 1955-56 Olds Fuel Pump block off plate
- Headers?
- Marking the distributor
- HELP!!! 72 350 Drivers Side Exh Manifold
- Alternator Spark?
- compression test dissapointing
- need some info
- Timing 72 350 2bbl Auto?
- Am I qualified?
- Boneyard has an oddity!
- 10 MPG? That sounds a bit high.
- More 403 Issues
- novice pushrod length question
- 75 ponitac 400 start up problems distributor fail
- 350 swap questions
- My Rocket 350 by Eric Flack in Kansas City
- 2.000/1.64 valves in 7a heads - need pictures for reference
- Any point in a cam?
- 394 into a 1957 / 1958 olds?
- Where and how to find out my engine size and year
- Pictures of moroso electric drive on Olds 350?
- '70 455 Mondello Intake and Valley Pan
- 400 pontiac sb engine tuning
- Timing Chain
- 350 intake
- terrible exaust sound
- Bang for your Buck
- Dampner question
- Distributor Gasket
- What is this part?
- help-1970 olds cutlass supreme rocket 350
- White Smoke
- olds 403 "roller tip" rockers problem
- Howards Cams Hydraulic Lifters?
- Hydraulic valve lifters
- Low fuel pressure with new pump
- Fuel Canister
- A/C clutch
- 403 oil pan question
- Need Advice!! Turning a 350 into 383 Stroker
- Coolant smell after parking
- Exposed Cylinder Block
- Look what I found
- 1970 350 GOLD PAINT ISO 'canada'
- Problem with the starter
- '70 Choke Pull-Off
- What's all this?
- Help: vacuum diagram
- Rochester 4bbl recommendations
- Fuel pump: elec. vs. mech.
- Cylinder Head Job
- Possibly Causes of Over Pressurize Crankcase
- Sticky goey intake deposits problem....
- slayer carb linkage
- What would you do if...
- 403 cranking issues
- Oil Fill Tube Removal
- Hooker Header Install 72 Cutlass SBO ?
- 1969 Cutlass Engine rebuild
- wild 70
- 350 issues please help
- can someone recommend a good place to get a reman carburetor
- Olds custom cruiser 1988 no coolant to heater core
- very mild street 350 build
- 7040255 BoolSheet?
- Head Bolts
- swapping accessories off a 307 motor
- Air, Fuel, & Spark, but still no start (46 Olds 6 cylinder)
- Now I'm ticked off......
- Performer RPM height with W25 Ram Air Hood
- 403 cam and magnum roller tip rockers?
- Help me ID my engine
- 5.7 diesel to gas rebuild?
- starter
- Peformer VS RPM as New Camshaft w/Performer Intake
- Intake
- timing chain symptoms?
- Qjet problem
- Anybody have a diagram of the accessory drive for a 307
- 556607 Crank, use for '70 350 4-speed?
- Rebuild Disaster - wrong cam. Who's fault?
- Head Gaskets
- Snakebit's numbers matching 350 rebuild
- Moore's Cylinder Head
- 330 Water pump pulley removal?
- Air Filter for 330 cid
- type of oil
- Buick 215 in my 63 F85 Cutlass
- Should I block off these water ports ??
- Need help, my steering pump servo is bad
- 350 upgrades
- Accel EFI on an Olds 350, '68 Cutlass
- Olds crate motor or rebuild the one I have?
- 403 head bolt install
- 70 vs.72 Harmonic balancer
- carb swap?
- Which Carburetor
- Edelbrock metering rods & springs
- Engine vacuum hose help!!!
- South Jersey Machine Shop?
- thoughts on this 403?
- edelbrock 3711 / 403 / #6 heads
- Where to Buy Major Overhaul Kit for 1964 330 ?
- 403 head alignnment dowels with 350 heads
- 1965 330 engine build, bored to 350...help
- oil pressure problem
- 1972 F85 Cutlass Engine Mount Change
- 350 Rocket Help
- Reversing JB Weld on Quadrajet fuel line inlet for restoration?
- SBO heads
- Quadrajet info needed!
- Which Cloyes timing chain for my 307?
- Heater Hoses Different Sizes?
- Which Oil Filter? Which Engine?
- 1967 330 rear main seal fixes
- Just in case you'd rather be blown....
- Which distributor?
- 350 troubles, carb issue or vacuum leak?
- Car seems starved for fuel on restart
- 350 overheating
- #5 Heads Porting
- 350 Olds Pulleys
- Rallye 350 no spark from good coil
- 403 Olds in a 77 Buick Electa overheating
- Carburetor
- 378 c.i.?
- Manifold Question
- What Cam?
- Power Steering brackets and Tall valve Covers
- 73 350 4bl
- Hydraulic Roller Cam for a 330
- Do I need "accessory bolt holes" on my cylinder heads?
- 350 olds engine over heating issues
- Oild Galley Plugs
- 403 valley tray gasket help
- Valve Cover Breather hole diameter
- Rochester 2Jet rebuild (Any tips?)
- What dip stick tube should I get??????
- Multiple Issues with 330 after rebuild - help with troubleshooting
- Rocker Arm Choices
- engine choices
- Reasonable Price
- Compression
- 64 - 330 carb issues?
- White Smoke
- Remove heads?
- Hypothetical Question...
- proof of life....
- 54 324 Question
- 403 with 350 heads assembly
- How Many Intake Manifold Choices for a 1965 330
- power steering pump 403
- Engine build - mileage, longevity, daily driver
- 4 blade fan upgrade options?
- Alternator Whine??
- 403 oil pump shaft pulled out
- factory roller lifters, any good?
- 67 330 or 75 350? What to do?!!!
- 403 timing gear set cover and crank "cup" spacer?
- Nice Sunday drive till he car died...on the ride
- Radiator Flush
- 1969 350 Engine Oil Suggestions
- h/o 307 to 350 swap details
- 68-70 350ci good?
- 350 rod orientation question
- Engine swap NJ
- 2 barrel to a 4 barrel?
- 3/4 race cam
- Mechanical Fuel Pumps - Options
- 350 Water Pump Choices - A/C
- Learning the hard way
- Replacing the 350 with a 455...
- Engine swap into?
- End Seals, RTV, or both?
- '55 324 Rebuild
- Radiator WTF?!?!
- 1984 Custom Cruiser Starting Problems Possibly Leaking Oil?
- 403 x ?
- 71 Cutlass S no fuel getting to carb
- My rebuild gone to s*it 2nd time
- Time for a motor swap!?!? Advice needed
- Bad or slack timing chain??
- 330 build up
- vacumme line diagram for 1970 350 with 4 barrel
- Either my new Craftsman Timing Light is a POS or my car has a mild cam
- Replacing the carb on my 72 cutlass s... any hints/tips?
- carb
- Shop diagnosed "Carburator leaking air from throttle shaft"....
- Heads - RockAuto.com Experience?
- Holley carb tuning question.
- Which Header Size?
- Which cam?
- Rochester Dualjet 210
- I need more power dammit!
- Timing Question
- Stock cam recommendations
- Steering pump pulley
- replace the quadrajet?
- What kind of performance to expect?
- quadrajet accelerator pump ?
- Valve cover baffle question
- Tuning/Building a Quadrajet
- Thermostat Housing
- roller lifters
- 71 cutlass 350 water pump bolts
- Spun Bearings
- Timing Experts, I need more timing!
- 1" pcv valve or a new grommet....any suggestions?
- Identifying an Olds Performer cam 3711
- problems with a cold start
- help setting distributor
- offset grind 350 crank for 2.1in chevy rod
- Need help with a QJet 4BBL part...
- what temperature should I be running?
- Camshaft 180 degrees out???
- Catalytic convertor on 71 cutlass?
- Is it time for more power?
- When installing an Edelbrock Performer intake..
- omega engine swap
- Air cleaner cover
- cam walk
- Carburetor help
- 1970 350 low shift ponts and lack of performance
- Q-Jet Electric choke (specifically 7042250)
- 307 leaking coolant
- 1972 350 Running lean on right bank
- Need an ID on this part, please.
- Heater Hose Size?
- 86 442 307 or 350
- No spark on a fresh build
- My shiny old engine
- Header Gasket leaking - desperate ---
- 350 engine v8 overheating on '75 Nova
- Duel exhaust and gas milage,Olds 215 V8
- All 403 cranks drilled to accept 4-speed input shaft?
- Noob question - numbered main caps
- cranks
- Believe I need to rebuild 371 rocket..Sugg?
- Head bolt sealant ???
- Whats different from 1970 to 71 in 350?
- What recommendations for 350 Intake gasket??
- Surging at wide open throttle
- Carb Fuel Problems
- Lifter Noise
- Olds high torque engine
