Cylinder Head Job
Old Aug 28, 2013 | 01:34 AM
TexasGunner's Avatar
Cylinder Head Job
I am plan to take my #7 cylinder heads off to have them rebuilt. Is there anything extra I should have done to them while I have them off the motor and in the shop? I plan to use the same pistons that are on the 71 block. Also I found some cylinder head composite gaskets that are .028 thick and plan to use them. Thanks.
Old Aug 28, 2013 | 08:08 AM
455man's Avatar
What are your plans for the rest of the motor?
Old Aug 28, 2013 | 10:25 AM
Basically keep it stock. Also it came with a Edlebrock performer intake. Think I will keep it on the block. Also just plan to do a full gasket change on the motor.
Old Aug 28, 2013 | 10:58 AM
455man's Avatar
If you are not looking for any more performance then I dont have any suggestions. basic head job would work fine. Since you are in South Texas you could look at blocking or partially blocking the heat crossover either in the intake or heads.
Old Aug 28, 2013 | 12:58 PM
Old Aug 28, 2013 | 01:34 PM
Make sure the machine shop is fully aware they are Olds heads. You might consider a light milling to compensate the difference between the thickness of your head gasket vs stock to keep your compression the same.
Inspect your lifters for wear, and don't mix them up. Also don't mix up your rockers/perches and pushrods.
Old Aug 28, 2013 | 01:54 PM
cutlassefi's Avatar
If they can't figure that out then I think I'd look for another machine shop.
Old Aug 28, 2013 | 01:58 PM
There is a machine shop in San Antonio that was suggested by some members. Miller's Machine shop.
Old Aug 28, 2013 | 02:00 PM
Have you ever been to S. Texas??
Old Aug 28, 2013 | 02:05 PM
have you ever been to s. Texas??
lol
Old Aug 29, 2013 | 07:51 AM
Majic Jack's Avatar
Machine shop CAUTION
Millers over on Grissom Rd. is in all probability the only one left with any degree of competence.
76Supreme350
Jul 21, 2010 11:54 PM
sborruso
May 19, 2010 09:27 PM
59-59-59
Mar 31, 2008 12:48 PM
72RocketPower
Feb 9, 2006 07:46 PM
