Coolant smell after parking
Old Sep 4, 2013 | 06:22 AM
coldfire's Avatar
After a couple of weeks of checking the floor, hoses, radiator etc. I think I finally found the source
This bolt at the back of the intake manifold had green around it
I was going to take it out and put some thread seal on it, but when I started loosening it coolant started to flow out so I tightened it back in.
Should tightening it be enough? Or do I need to do something more?
Old Sep 4, 2013 | 06:31 AM
You need to drain some coolant out of the system to repair as the plug is below the current water level.
Old Sep 4, 2013 | 01:12 PM
tru-blue 442's Avatar
Old School Olds
X2.
There is a cleaning trick where
you can use a good battery terminal
cleaner to do the job for the hole if
you don't have a round steel brush.
A wire brush on the plug followed up
with some teflon tape, good to go.
Old Sep 5, 2013 | 08:41 AM
Run to Rund's Avatar
It appears to be a 3/8" NPT plug. The factory used pipe plugs. Seal it with Permatex or RTV.
Old Sep 5, 2013 | 09:09 AM
Octania's Avatar
Teflon tape, maybe, but it looks hokey IMHO
RTV, no, wrong application for that stuff
Form-a Gasket #2 would be perfect, or teflon based pipe sealer spooge in can.
Drain the radiator down to as far as need be, make the repair, re-fill. '
One advantage of the F.A.G.#2 over say teflon tape is that you don't have to tighten as much to get a seal, and with tapered threads in an AL casting, excess torque can lead to a broken casting.
Old Sep 5, 2013 | 12:36 PM
Old School Olds
Pipe dope works fine.
Teflon can be wrapped
as many times as you need
to go around the plug.
Much cleaner version and
removal is a snap.
Just one man's opinion.
Arrowstorm
Suspension & Handling
25
Jul 29, 2015 05:52 AM
fv64olds98
Oct 24, 2014 07:49 PM
ziff396
Sep 7, 2014 05:04 PM
Dan Wirth
Paint
37
Sep 21, 2009 08:11 AM
Keieljun
Nov 8, 2007 01:30 PM
