2.000/1.64 valves in 7a heads - need pictures for reference
Old Sep 19, 2013 | 10:04 AM
Seff's Avatar
Going to put BBO valves in my 7a heads for the stroker build CutlassEFI is building for me. Given the total lack of Olds experience on this side of the pond, I'm looking for pictures of SBO heads with valves of those sizes, so I can give my machinist something substantial to work towards - and so I know how to port the heads ahead of the larger valve size being put in. If anyone has anything of that sort, it'd be a big help. Thanks.
PS: Furthermore, when I give my machinist the valves and the heads, I want him to make sure the valve stems are set at an even height across the board, yes?
Old Sep 21, 2013 | 07:34 AM
Seff's Avatar
Alright, let's make this easier for you guys.
I've removed the red circled elements so far:
Do I also want to remove this ridge?
Do I need to do anything further to ready the heads for a valve job that gives me bigger valves?
Old Sep 21, 2013 | 08:40 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I would grind the area around the guides too. I believe transitioning the bowl to the bigger valves is also important.
Old Sep 21, 2013 | 08:45 AM
Seff's Avatar
Sounds fair. Should I just kinda "flare out" the last quarter inch before the valve seat to the new diameter`, or is that too much?
Ctott70
Jul 17, 2022 05:16 AM
bob p
Mar 19, 2015 09:07 AM
import extermination
Nov 29, 2011 09:05 AM
mike623
Feb 13, 2011 09:39 AM
Oldsguy
Aug 31, 2007 07:49 AM
