Which Carburetor
Old Aug 7, 2013 | 10:09 AM
rookieoldsguy72's Avatar
Which Carburetor
Just got back my 350 mtr from rebuild it was a stock 1972 mtr single exhast, 2 barrel, points distributor. Had the Block bored 30 over new Speed Pro Pistons ZL2320F30,CCA 1442 Rocker conversion kit, CompCam 42-222-4
New hyd Lifters& Pushrods,7A Heads, HEI distributor,Flo Tech Headers,Edelbrock #7111 intake .Really would like to drive the car until late fall then Transmission and 3.42 Posi unit. Hopefully 507 olds to rebuild my rearend.
I am only 20 years old have already bought the wrong rearend and Cam. This car was my greatgrandmothers Body and Interior are in Great shape Trying to WAKE UP THE OLD GIRL I'M not as knowledgeable as you guys
Thanks in advance
Old Aug 7, 2013 | 11:01 AM
cutlassefi's Avatar
Thanks in advance
Wrong pistons, wrong cam imo, sorry. It'll probably ping even on premium pump gas, unless you're a few thousand feet above sea level.
ihengineer76's Avatar
A 650 Holley with vacuum secondaries would be a pretty good match for this setup if you get your compression down.
Old Aug 7, 2013 | 03:41 PM
jag1886's Avatar
I use an 80457 Holley on a very similar engine works good.
Old Aug 8, 2013 | 09:26 AM
c-towndave's Avatar
jag,
Is that 80457 Holley a bolt on for a stock 350 Olds engine? Need to replace my old tired carb.
Old Aug 8, 2013 | 03:37 PM
jag1886's Avatar
Originally Posted by c-towndave
jag,
No it fits and aftermarket manifold.
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
yeahbuddy
Jun 1, 2010 05:38 AM
ViceGuy
Mar 25, 2007 01:43 PM
thomaswatk
Mar 22, 2007 01:31 PM
