Cutting off old exhaust
Old Oct 5, 2013 | 12:58 PM
Macadoo's Avatar
IF I can't get the bolts unstuck (most likely original 350 exhaust) and I have to cut it off, any issues with driving on straight pipes for about 20 miles to the muffler shop? Besides a ticket, I mean.
Old Oct 5, 2013 | 01:02 PM
don71's Avatar
same but different
Nothing wrong with that.
Old Oct 5, 2013 | 01:07 PM
brownbomber77's Avatar
I drove mine with the cat cut off before I put headers on it. Sounded real trashy comin' outta the Y-pipe. How do you expect the exhaust shop to get the manifold bolts out if you can't...? haha
Old Oct 5, 2013 | 01:31 PM
You may be able to pull the engine after disconnecting the manifolds. At that point work on the exhaust bolts.
Old Oct 5, 2013 | 07:24 PM
Macadoo's Avatar
Thanks guys. I was thinking a sawz-all or my dremel. PITA either way but I'd rather deal with the manifolds after the engine is out. Still, given enough time, the penetrating oil should eventually work.
Old Oct 6, 2013 | 09:45 AM
If you are concerned about the old wive's tale of cold air somehow getting sucked into the exhaust and causing damaged valves, that's a total myth. The one thing you do need to be worried about is, are the cut off pipes pointed at anything on the chassis that could be damaged by heat (e-brake cables, hoses, wires, etc)?
Old Oct 6, 2013 | 10:29 AM
Macadoo's Avatar
Good timing again Joe. I'm getting ready to try out the ol' sawz all. Already snapped a bolt.
RAMBOW
Jan 9, 2018 01:51 PM
PGH Cutlass
Nov 11, 2014 08:22 AM
Hooker29
Apr 17, 2012 12:59 PM
Wilson05
Suspension & Handling
Oct 17, 2009 07:10 PM
knightvd
Oct 10, 2007 05:26 PM
