70 vs.72 Harmonic balancer
Old Aug 8, 2013 | 06:42 PM
I have been having timing issues on my 71 Cutlass and my 70 Vista Cruiser, both 350's, so I checked both harmonic balancers to see if they had slipped or spun. I used a screwdriver in the #1 spark plug hole. The 71 was just about perfect but the 70 I think has slipped, which explains why it spark knocks something terrible when set anywhere near where it's supposed to be. So I went out to my 72 Cutlass parts car and removed the balancer from it and put it on the bench and after cleaning off the crud I can see the marks that are on the hub and the weight are exact so I can tell it hasn't slipped. I also removed the dist cap on the Vista, and found I have about 10 degrees movement in my timing chain so I defiantly need to replace the chain. My question is can I use the balancer off the 72 on the 70? The 71 and 72 are thicker than the one on the 70. Thanks for your advice, Greg.
Old Aug 11, 2013 | 06:50 PM
Anyone know about this? Thanks, Greg
Old Aug 11, 2013 | 07:42 PM
svnt442's Avatar
Go ahead and use it.
rroth01
Dec 3, 2016 06:27 AM
Gert3116
Apr 23, 2008 08:53 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
