PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31
  1. new problem electrical
  2. 1974 or 1971 Heads
  3. Intake ID
  4. Which Intake should I get?
  5. fan shroud
  6. money to spend.....just need some advice
  7. timing 350 rocket
  8. Need some advice and/or opinions????
  9. A5 intake
  10. 7111 Edelbrock and Holley install
  11. Swapping Carbs
  12. 79 trans am. Help please
  13. oil galley plug wrong ?
  14. Extra soft plug
  15. 330 #1 & #2 heads question
  16. A/C Confusion
  17. Will these valves work in my heads?
  18. Fuel Gauge not working
  19. Name That Cam
  20. 1972 Ac bracket placement
  21. Why'd my "Oh Sh*t!" light come on?...
  22. Name That Piston
  23. Cam movement (walking?)
  24. 67 fuel pump
  25. Stupid Question Needs Answer
  26. Chambered vs magnaflow or flowmaster etc...
  27. Choosing valve springs
  28. Foam
  29. Pushrod Length
  30. Dipstick Length
  31. Valve Covers
  32. White foamy stuff
  33. frost plug problem
  34. help finding a mechanic
  35. 62 Olds Ninety Eight
  36. 350 Piston ??
  37. Ac Parts
  38. Carb ID Clarification
  39. Where to Find a replacement?
  40. [Dumb] Intake Manifold Cleaning Question
  41. 66 330 intake gasket ?
  42. 350 olds 72 s with a problem
  43. rocker adjustment
  44. Valve Stem Lengths?
  45. 76 olds
  46. Engine Vibration
  47. 350 overheat
  48. Relocating my altenator
  49. 350 exhaust
  50. 330 exhaust manifolds
  51. what cam for 330?
  52. Is this a factory alum. intake? Older Edelbrock?
  53. A "350" is never JUST a 350...
  54. Irregular miss
  55. 1972 cutlass 350 block
  56. '57 Olds 371 Valve Seats
  57. HOLY CRAP! (& carb update)
  58. Quadrajet to Edelbrock manifold adaptor question?
  59. oil filler removal
  60. Intake valves
  61. Intake assembly question
  62. 1970 Rocket 350 balanced internally or externally??
  63. Oh Snap!
  64. Getting the carb right the first time...
  65. Curious about intake gaskets
  66. oil leak from carb
  67. Adjustable roller rockers
  68. not another 350 cam question
  69. 330 dipstick help.
  70. 330 stock head help!
  71. exhaust manifold removal
  72. 350 pulley hub on 330?
  73. Now confused
  74. Supreme Headers
  75. Banshee belt(s)...
  76. Radiator fan for 64 88
  77. Intake/Exhaust valves condition
  78. Where did I go wrong - HP and Torque
  79. solid webing 403
  80. timing
  81. 383 stroker
  82. Heads
  83. Piston volume
  84. 350 numbers
  85. Ballencer Pulley
  86. Carb??
  87. Silvo-lite 1433
  88. Best 1972 Cutlass Exhaust Set Up
  89. Machine shops in AZ
  90. Rebuilding in cold weather
  91. Heat crossover on intake
  92. Flow tech headers
  93. Exhaust flow plates?
  94. Degree kit
  95. Larger Valves in 7a Stock Heads
  96. Headers 1971 cutlass
  97. Need Carb Help
  98. '69 350 with a/c radiator
  99. What's wrong with the 350 in this ad?
  100. strange ignition problem after carb rebuilt. please help!
  101. Carbon build up in my 330
  102. 355 Olds build cost and parts list
  103. Freeze plug!!
  104. At what temp is "cold smoke" a bad sign?
  105. 1968 403?
  106. EXHAUST PROBLEM What do i do?
  107. Good looking Oldsmobile 350 Rocket chrome Valve Covers and Air Cleaner
  108. What is this?
  109. rear main seal
  110. Valve covers
  111. Looking for 72 Cutlass vacuum diagram
  112. Tune up and dwell
  113. 66 coolant leak
  114. 303 head and intake interchange
  115. Car vibrates too much at idle
  116. 350ci Stock Cam Questions
  117. More Power to a stock Rocket 350!!!!
  118. What HP number am I looking at?
  119. 350 rocket but what year??
  120. Building 350 Rocket
  121. headers for Holland
  122. My Soon to be build...give opinions!!!
  123. Compression Ratio
  124. #5 cylinder head /piston question
  125. Screeeeeeeeeeeee
  126. Starting issues?????
  127. Vacuum hose replacement help?
  128. 355
  129. Oil smoke when starting
  130. Idol stop seloniod
  131. HELP! Can't Get Motor Started...1968 Cutlass
  132. 330-350 Questions
  133. Off-Idle engine stumble (near stall)... how to troubleshoot/correct it?
  134. 1957 Oldsmobile J2
  135. transmission filter 1964 88
  136. 403 head gasket
  137. Ignition Upgrade Ideas?
  138. 350 Head Flow or Desktop Dyno profiles??
  139. Carb. rebuild
  140. Martians & my 307
  141. 350 Carb Swap Holley 1850 to QJ702251
  142. Fuel Pressure Regulator
  143. timing marks
  144. crankcase evac
  145. 350 dipstick
  146. Starter Problem
  147. MSD not working
  148. Engine temp at 150
  149. oil pressure sendinbg unit
  150. Vin# history
  151. Green stuff growing on Engine
  152. Chrome Accessories?
  153. olds 403 what ya think?
  154. Engine oil
  155. Unleaded gasoline?
  156. 55 324 questions
  157. Power Steering Pump Pulley Nut Direction?
  158. Help! 670 holley vs eldebrock 600 and stall converter question
  159. thermostat housing bolt
  160. Moving brake dist block to accommodate headers
  161. OPG 350 exhaust manifolds
  162. slow and fast idle specifications
  163. Hello my engine "warbles"!
  164. Timing chain-what type- dbl? true?
  165. throttle lever stuck
  166. Chrome Accessories?
  167. 1970 Ralley 350 heads
  168. No oil flowing to the right head!!!!!! Help!!!!
  169. curious on cheap 350 builds
  170. Noise in the top end
  171. Cam
  172. Holley vs Edelbrock
  173. 350 rebuilt problems
  174. Questions on Rebuilt 350 Purchase
  175. 215 motor and automatic tranny
  176. carb and kick down bracket
  177. 350 Rebuild
  178. need help on 330 rebuild!!
  179. ? about '74 Olds350
  180. the right carb or a 71 350 olds rocket
  181. cooling
  182. ramrod heads
  183. Trying to Restart My 330 1967
  184. Pulling Heads on 350
  185. cam suggestions please
  186. olds 403 pcv valve
  187. 350 rocker arm bolts
  188. Need help removing engine!!!!
  189. Carb Backfire
  190. Which pistons do I need?
  191. Float Adjustment on Rochester 4 Barrel
  192. Connecting Rod Specs
  193. Bone stock '72 350 4bbl with 3.42 posi...
  194. 72 Olds Cutlass Supreme Air Clearner
  195. What HP number would I be looking at
  196. how much horsepower?
  197. popping through the carb
  198. 350 Water pump toast
  199. Rebuilding 7028251 Quadrajet for 350
  200. Removing Carbon Build up
  201. pistons 30 over 350
  202. holley carb setup on 350
  203. Things to Consider, 350 Build
  204. Things to Consider, 350 build
  205. Oil Filter Base Question
  206. 53 olds fuel pump
  207. 61 fuel pump
  208. Rochester 2G Idle Problem
  209. Ok littel confused / frustrated
  210. Timing dots
  211. valve keepers (locks)
  212. Help Needed Throttel Bracket Issue
  213. pressurized coolant?
  214. heater core
  215. Unkown bracket on 1970 Rochester carb
  216. Good intake for a 350...
  217. Bolts long enough for engine stand?
  218. Spark Plugs and Valve Cover Gaskets
  219. Best way to refinish Edelbrock intakes ??
  220. Rough start on unlevel surface?
  221. 1969 oldsmoble headers
  222. 350 Cam selection - what's your choice?
  223. 67 330 39* cba???
  224. blown Head gasket
  225. belts en pulleys
  226. engine info 71 350
  227. Need help with head gasket thickness
  228. noise after braking
  229. Swapped Intake, Need help
  230. stock rods with bronze bushings
  231. replacing 307
  232. Mystery 215 V8 valve covers
  233. Quadrajet cold start fast idle stuck
  234. 307 bored .030 over=?
  235. Balancer bolt
  236. RPM Heads - Alt Bracket
  237. GM Mechanical / Vacuum Advance Specs Documentation?
  238. 72 Olds Cutlass Supreme Pie Pan?
  239. 64 330 cutlass matching numbers?
  240. 1969 but has 1970 motor
  241. 4 barrel throttle linkage question. Help Please.
  242. 70 350 - Where to put temp sensor for fans ??
  243. how can i hook up gauges
  244. smoke in engine
  245. Quick reference question - Timing for '78 260 (yikes!)
  246. parts for '72 350 rocket???
  247. Problem rockers
  248. Oil Light Comes on in Idle
  249. compression question
  250. Oil pump priming?
