350 rebuilt problems
Old Nov 4, 2010 | 06:19 AM
thatguy32567's Avatar
So i have a few questions about my rebuilt 350 rocket. I have broken it in properly and now it has about 2000 miles on it. Everything seems to run great except if i accelerate quickly to more then 40 mph. When i let off the gas it backfires for a few seconds then stops. Any ideas on what it is or how to fix it?? please email me directly with answers. keefe_neise@yahoo.com
Old Nov 4, 2010 | 06:46 AM
Rickman48's Avatar
You must have loud exhaust with short or no tailpipes!
The rich air/fuel mix in the intake manifold comes into play, along with reversion, cam overlap, etc.
Ever hear a car with open headers - same thing!
Put taipipes on it - gone!
Old Nov 4, 2010 | 07:23 AM
Oldsguy's Avatar
Past Administrator
Pre-ignition because of incorrect timing might be it.
Old Nov 5, 2010 | 01:55 AM
Redog's Avatar
^^ agreed
Old Nov 5, 2010 | 05:38 AM
bkeese's Avatar
  • Exhaust leak (Headers are good for this) - which is essentially what Rickman said
  • Timing wrong
  • Valves not adjusted correctly which will end up burned
You didn't say is it in the exhaust or back through the carb?
Old Nov 5, 2010 | 05:42 AM
cutlassefi's Avatar
Just my .02 but it typically won't do that under no load high vacuum conditions.
I'll go with rich or even lean mixture from various causes, or if you have a bit of timing in it and you have your vacuum advance hooked to the manifold vacuum under high vacuum conditions which is what you're describing, it will pull full vac advance. Might check there first.
Or as stated, you could have an exhaust system issue.
chasman414
Jun 25, 2020 07:05 AM
Arrowstorm
Aug 14, 2014 04:07 PM
brandon reynolds
Apr 10, 2012 12:06 PM
65cutty
Tech Editor's Desk
May 31, 2009 09:03 AM
awspeich
Nov 30, 2006 07:28 AM
