Name That Cam
Old Feb 9, 2011 | 07:02 PM
dsolomon's Avatar
Name That Cam
Well I tried this with the pistons and got some great feedback. Maybe it will work with this cam.
I pulled the cam from an engine I just purchased. Its a fresh rebuild but I wanted to check it out. Anyway... there are some numbers stamped into the rear face. They are 941129 and J274. The front of the blank is painted red and has CMC and CWC cast into the blank. The rear of the cam is painted purple and D4 99-08 OS is cast in. Could be 80-66 SO but I think the previous is correct. DOes any of this help to identify the cam?
Old Feb 10, 2011 | 04:46 AM
cutlassefi's Avatar
I got nothing in a search so you might want to put it back in and throw a degree wheel and dial indicator on it. Or take it to a shop that has a Cam Pro.
It's probably stock or close to it. Most major aftermarket cam companies mark their cams for easy indentification.
Old Feb 10, 2011 | 09:04 AM
dsolomon's Avatar
Found some information on a Camaro forum. Looks like the CMC may be Cam Machine Company. They manufacture for OEM's and also sell aftermarket cams, probably to rebuilders.
Camshaft Machine Co.
717 Woodworth Rd.
Jackson MI 49202-1654
United States
517 787-2040
Going to give them a call and see if they can cross the numbers. I suspect that it is going to end up being a stock cam but worth a call.
Old Feb 10, 2011 | 09:38 AM
cutlassefi's Avatar
717 Woodworth Rd.
United States
517 787-2040
They also supply most everyone with the generic grinds and sell cores to the rest.
Old Feb 10, 2011 | 10:01 AM
dsolomon's Avatar
So then it may not be thiers.... Oh well. I wasn't expecting much.
Any recomendations on a cam for this car. I am looking for something with a noticable idle for a street machine. RPM range should probably be around 1500 to 6000 as all of the engine components are stock quality.
The specs are:
350 with #6 heads (2.00 intake valves)
Performer RPM #7111 Intake
Holley 650
Headers with 2-1/2" dual exhaust
TH350
3.23-3.55 gears (still undecided)
Old Feb 11, 2011 | 09:47 AM
dsolomon's Avatar
How about the Comp 268H or the XE268H?
Old Feb 11, 2011 | 10:37 AM
cutlassefi's Avatar
Compression ratio?
If around 9.0:-9.5:1 then an Erson TQ40 would be perfect, that's what they were designed for, stock cast iron headed American V8's. Specs are 220/228 @ .050, .504 lift, we can do it on a 108 if you want a bit more tone and low end punch.
Jmo.
Old Feb 12, 2011 | 12:42 PM
dsolomon's Avatar
Guess it would help to give that information. I cam up with 9:1.
Where are Erson cams purchased?
Old Feb 12, 2011 | 03:32 PM
cutlassefi's Avatar
For a 9.0:1 I'd do the TQ40. You can get them right from Erson but they;'re cheaper from me, custom or off the shelf, same price, $225.00 for cam and lifters plus the ride.
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
blue72regency
Oct 16, 2007 05:27 AM
cooltat2z
Jul 12, 2006 09:19 PM
