Balancer bolt
Old Oct 4, 2010 | 06:45 PM
Redog's Avatar
Balancer bolt
Hey everybody.
What size head is on the balancer bolt? I forget if it's 1 and 1/8 or 1 and 1/16
Will I need to use a flywheel stop of some kind when removing and replacing said bolt? And does it have to be anything speical or can I use anything.
All I need is the correct size Impact socket and oil pan gasket and I can throw in my timing chain and 5 qt oil pan and all the goodies. Heads are going to have to wait a while though
Old Oct 4, 2010 | 06:48 PM
2blu442's Avatar
A 1 1/8" Socket is what you need.
You may have to experiment to see what it takes to hold it in place while you break it loose. I've actually had to soak one with liquid wrench for a few days and use an air wrench to remove it. Hopefully yours won't be that bad!
John
Old Oct 4, 2010 | 07:10 PM
Run to Rund's Avatar
II prefer to block the flywheel but you can make up a long bar and two 5/16" grade 8 or better bolts to secure it to the damper hub, and run to a frame rail.
Old Oct 5, 2010 | 05:27 PM
Redog's Avatar
The engine is not in a car right now
tmcfall
May 29, 2024 12:41 PM
Sporty45
May 24, 2015 06:44 AM
olds4life
Oct 5, 2010 05:18 AM
2blu442
Jul 16, 2010 07:26 AM
dman0712
Drivetrain/Differentials
Mar 16, 2010 07:40 PM
