Balancer bolt won't budge
Old May 19, 2015 | 11:09 AM
Sporty45's Avatar
I'm having a hard time trying to loosen the balancer bolt on my 77 350 motor. It is on a stand, heads and intake off, and I have even gone as far as putting a 4' pipe on my breaker bar, but I can't give it a full yank because it just want to tip the stand over. The motor has been appart before I ever got it and think I am in deep doodoo if someone put loctite on the bolt. Any suggestions on how to loosen the dang thing?
Old May 19, 2015 | 11:12 AM
pogo69's Avatar
morgan
1/2 drive air gun will remove it
Old May 19, 2015 | 11:40 AM
Sporty45's Avatar
That was the first thing I tried! I cranked it up to about 110lbs at the gun and nothing. I even tried hitting it in both directions hoping I could shock it free.
Old May 19, 2015 | 11:46 AM
frankr442's Avatar
If you don't have air, maybe an electric impact. Never mind, I type slowly.
Old May 19, 2015 | 12:02 PM
brownbomber77's Avatar
Try a bigger impact. 110 is enough to get lug nuts off. Next step is propane or acetylene. Should be able to heat it up locally without damaging the rubber ring on the balancer
Old May 19, 2015 | 01:09 PM
Take it off the stand and lower on something with support. Then break it loose.
Old May 19, 2015 | 01:44 PM
Sporty45's Avatar
I typically have my shop air set at 90psi and don't usually have any problems breaking lug nuts(or just about any other nuts/bolts) loose. On the rare occasion I do, I jack it up to 110psi and it works fine.
Sporty45's Avatar
I might just set it back in the frame and do just that!
Old May 19, 2015 | 02:34 PM
Or you can lay it on an old tire.
Old May 19, 2015 | 02:36 PM
Sporty45's Avatar
Not a big deal to set it in the frame, it's pretty open!
Old May 19, 2015 | 02:40 PM
Is that a Corvette front clip? If someone put locktight on the bolt it may need some heat to loosen it up.
Old May 19, 2015 | 03:10 PM
Sporty45's Avatar
Yup.
It's going to take a lot of heat to get all the way to the threads. It's a good thing I have an oxy acetylene torch!
Old May 19, 2015 | 03:30 PM
We did the same thing to a 67 Vette frame with the addition of using the late model back half also. Nice work!
Old May 19, 2015 | 03:34 PM
Sporty45's Avatar
I actually looked at using a vette rear suspension, but didn't want to narrow the rear frame to do it.
Old May 19, 2015 | 03:40 PM
What is this going in?
Old May 19, 2015 | 03:55 PM
Sporty45's Avatar
<------This
It's my 47 Model 66 Coupe
Old May 19, 2015 | 03:56 PM
Cool, why not start a build thread, I'm sure there would be plenty of interest.
Old May 19, 2015 | 04:03 PM
Sporty45's Avatar
I plan to, I just want to get a little more done first. Plus get some more pictures. I do have a little bit about it in the vintage Olds section, in the "1946 1947 and 1948 How many own them?" thread: https://classicoldsmobile.com/forums...-own-them.html
Old May 19, 2015 | 04:08 PM
lunaboy's Avatar
The Rocket Astronomer
i use a breaker bar and a large hammer . give it a good wack but be careful to hit it square or it will jump off and hit you where the sun don't shine
Old May 19, 2015 | 04:10 PM
RROLDSX's Avatar
If you can secure the motor, place your breaker bar again the frame or floor and bump the engine with the starter. That usually does it.
Randy
Old May 19, 2015 | 04:21 PM
Sporty45's Avatar
Randy
Ummm... that's not gonna happen!
Old May 19, 2015 | 04:52 PM
I'm going to have to go over to that forum more often, some nice stuff going on over there.
Old May 19, 2015 | 04:57 PM
Sporty45's Avatar
Yes there is! It took me forever to find this place. For some reason this site never came up in any of my searches. It wasn't until I was searching out how to decipher my engine number that it came up. I am beyond happy I found it!!
There are some incredibly smart people here.
Old May 19, 2015 | 05:21 PM
M-14's Avatar
Make a crank holding tool.
Old May 19, 2015 | 05:36 PM
brown7373's Avatar
Is 110 pounds on the gun the air pressure or the torque? The bolt is supposed to be very tight, 160 lb. ft. minimum.
Old May 19, 2015 | 05:40 PM
Sporty45's Avatar
The 110lbs is the air pressure at the gun. I can run the compressor up to about 150 or so before it shuts off, so I tried bypassing the air regulator and running my impact gun right from the compressor at 150 psi and it still wouldn't budge.
Old May 19, 2015 | 05:47 PM
Sporty45's Avatar
Yeah, I have an old head bolt going through the flexplate and wedged against the block and the engine stand. The crank isn't moving at all, it's just when I put too much pull on the breaker bar(with a pipe on it) it just wants to tip the stand. I am going to mount the engine in my frame and I'll be able to get more pull on it. Maybe tomorrow, we'll see how my day goes. I spent a good amount of time in the garage today because it rained all day!
Old May 20, 2015 | 02:01 AM
rustyroger's Avatar
'87 Delta 88 Royale
Try whacking the bolt head with a big hammer then having another go. I've shifted some big fasteners out on breakdowns that way.
Roger.
Old May 20, 2015 | 03:25 AM
Sporty45's Avatar
Will do. I soaked it in WD40 yesterday and I'm hoping that it helps me out today.
Old May 20, 2015 | 10:32 AM
SkylinesSuck's Avatar
I had the same issue with my engine on a stand. Impact gun, heat, hammer, nothing would break that bolt. I wound up going down to the local hardware store and bought some cheesy china brand electric impact gun that wasn't your typical gun. It kinda "spooled up" for a few seconds then gave you one powerful "WHAM!" then started spinning up again. It's actually 12v powered too believe it or not. I was VERY skeptical it would work but for $20, why not. Worked great. It would take forever to do something that needs a lot of turning, but to break something free, I've seen nothing more powerful. I'll see if I can find a link. I'd tell you the brand and store, but I'm in Japan so it probably wouldn't help much. I'm sure the States has got to have something similar.
Old May 20, 2015 | 02:58 PM
  #31
Sporty45's Avatar
Success! I sprayed it up good yesterday, let it sit overnight, then went at it again today. First I tried the impact gun at 150psi with no luck, then put the 4' pipe on my breaker bar and gave it a good pull and it let go. Never had one fight me so hard! Thanks for all the help, guys!
Old May 21, 2015 | 01:07 AM
  #32
rustyroger's Avatar
'87 Delta 88 Royale
Excellent news, lets hope that's the only problem you have.
Thanks for letting us know btw.
Roger.
Old May 21, 2015 | 03:56 AM
  #33
Sporty45's Avatar
Oh man, if this is the only problem I encounter during this build I will be thrilled!
Old May 21, 2015 | 07:06 AM
  #34
ELY442's Avatar
Sometimes an impact gun don't work. I couldn't get a lug nut off on a Mack truck while I was using an 1" impact gun with 175 psi. So I use a 3/4" ratchet with a 5" pipe and it broke free because I use leverage. Impact gun don't have leverage.
Old May 23, 2015 | 03:22 PM
  #35
Warhead's Avatar
Sorry I am late to this party.
Next time, tighten it, then loosen.
Impact or breaker bar, either one.
It works.
Old May 23, 2015 | 06:09 PM
  #36
Sporty45's Avatar
It works.
Yup, that's exactly what I did...for 2 days straight! That didn't work, so I oiled it up good with WD40 and let it sit overnight, then the next day I whacked it good a few times with my biggest ballpean hammer and hit it a few more times with the impact, then put the 4' pipe on my breaker bar and that got it.
Old May 23, 2015 | 07:09 PM
  #37
M-14's Avatar
I've actually heated up the bolt head on cranks, the makes the bolt longer & relieves the tension enough to unscrew it.
Old May 24, 2015 | 04:01 AM
  #38
Sporty45's Avatar
Makes sense, the heat was coming out next if I didn't get it with the oil and breaker bar!
Old May 24, 2015 | 06:23 AM
  #39
M-14's Avatar
The reason I said to make a crank holding tool is that you can pull up on the holder while pushing down on the breaker bar, so the engine wouldn't topple over on to the ground. They really help when the engine is in the car too.
Old May 24, 2015 | 06:44 AM
  #40
Sporty45's Avatar
Ah, OK, I got ya now. I thought you were just talking about something to immobilize the crank so it wouldn't spin while I was pulling on the breaker bar.
tmcfall
May 29, 2024 12:41 PM
stevengerard
Sep 10, 2014 03:17 PM
Mr. Goodtool
Dec 24, 2013 06:51 PM
Redog
Oct 5, 2010 05:27 PM
2blu442
Jul 16, 2010 07:26 AM
