Now confused
Old Jan 4, 2011 | 08:03 PM
Kyle's 77 Cutlass's Avatar
Now confused
Okay, like I said I have 2 engines. The one for sure is a 77 block which is in the car. my spare thought it was a 76 ran the numbers to the chart, found the number just above the water pump, #395558 2 and the heads are #8 SWTF??? Any ideas guys
Old Jan 4, 2011 | 08:15 PM
2blu442's Avatar
If the heads are original it could be any year from a 1973-76ish? You need to check the vin number stamped in it. The first digit will be a 3 for Oldsmobile, the second will be the year of the car it came in. 3=1973, 4=1974, etc. If your not sure where the vin is stamped check this thread:
https://classicoldsmobile.com/forums...s-engines.html
John
Old Jan 4, 2011 | 08:41 PM
John
Okay went and looked #36M171518 and on the intake manifold #411990
Old Jan 5, 2011 | 06:33 AM
So it's a 1976 motor, which is consistent with the block casting no. and the #8 heads. Why so confused?
Old Jan 5, 2011 | 01:06 PM
captjim's Avatar
Yeah, rebuild with flat tops, deck .015, use a .028 gasket, you end up at 9.2 to 1 +/-, perfect for a street engine.
Old Jan 5, 2011 | 04:49 PM
why confused?
[QUOTE=2blu442;240408]If the heads are original it could be any year from a 1973-76ish? You need to check the vin number stamped in it. The first digit will be a 3 for Oldsmobile, the second will be the year of the car it came in. 3=1973, 4=1974, etc. If your not sure where the vin is stamped check this thread:
John[/QUOTE
at first I had thought it was a 76 block,got the numbers from the block, looked on line most places said it was around 70'ish block.Thats why I was a little. Ran the second set of numbers you told me and that makes more sense. THANKS
Old Jan 5, 2011 | 04:51 PM
Cr
Where would the CR sit if the deck was at zero?
Old Jan 5, 2011 | 04:58 PM
cutlassefi's Avatar
You probably don't want to have only a .028 gasket with a zero deck. That's getting a little tight.
Old Jan 5, 2011 | 07:18 PM
captjim's Avatar
I assume too much, my bad. The reason for cutting .015 and using a .028 gasket is to keep the price down. Speed Pros generally sit .025 +/- down, so, cutting .015 off the deck that makes it .010 down plus the .028 gasket gives you optimum piston to head, right around .040. You could zero deck and use a .040 gasket, but that is just an extra cut of the top of the block.
Here is a calculator, start using it,
http://www.angelfire.com/fl/procrastination/motor.html
Old Jan 5, 2011 | 07:35 PM
I would but I don't know any measurements of my engine, even for me to rebuild an engine to this much power is to much for me.all I've done was stock with an rv cam.
Old Jan 5, 2011 | 07:38 PM
I will leave the engine in your hands. You build, I will enjoy.
oldsdroptop
Jun 2, 2009 07:03 PM
daves62
Feb 18, 2009 04:01 AM
SuperSickBoy
Dec 18, 2008 05:00 AM
shaunr
Dec 23, 2006 07:55 AM
newoldracer
Nov 30, 2006 10:36 AM
