PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31
  1. Worried: Need Advice/Opinions
  2. Question about adding #5 heads to 350
  3. Just spoke with the guys at edelborck about intake and carb combo haha
  4. gauges help help help
  5. Help with Bad Bad Boat
  6. rear main seal question
  7. ring gap
  8. new issue with CS 330 motor
  9. help with 1406 and 7111!!!!
  10. Radiator overflow advice
  11. ok stupid question again
  12. help car won't start
  13. Where is oil pressure switch?
  14. more power 403ci help
  15. oil pressure !?!
  16. Where is the oil sending unit
  17. 1970 Rocket 350 Holley 1850 Carb issue
  18. Intake exhaust plugs
  19. small block chevy 350 given to me 4 bolt main
  20. Maylene, my 1967 CS, let me down today
  21. 1970 delta 350 2 barrell
  22. Edelbrock throttle cable bracket
  23. What kind of exhaust is this?
  24. What carb is this?
  25. 1969 Cutlass Needing Mechanic
  26. Mobile one high mileage synthetic oil
  27. Rpm question
  28. Fuel Pump 1956 super 88 olds
  29. header bolt size 70 cutlass
  30. 403 hei
  31. Oil out the breather
  32. Best way to start a car after sitting up for 6 years
  33. Edelbrock carb parts.
  34. which carb
  35. 77 olds 88
  36. Pulling out a chevy
  37. HEI Questions...
  38. 8 heads
  39. Need gaskets and what else for edelbrock 7111 intake?
  40. 1971 Cutlass Radiator
  41. Plug wires mixed up
  42. Cold Air intake options
  43. Toronado oilpan on a 350
  44. 70 rallye 350 (engine missing)
  45. Coolant question
  46. Intake manifold
  47. gas tank vent lines
  48. out of round or bore taper
  49. head swap
  50. exhaust trumpets on 2 1/2 in pipe
  51. questions about a some gears from a 10 bolt.
  52. bearly turns over
  53. synthetic or no
  54. How to install rear main seal questions
  55. engine ?
  56. Lost cam card,need the info Sealed Power # KC1024R
  57. engine
  58. question about vacuum readings?
  59. 330ci Heads
  60. (Not a) 350 Chevy Small Block?
  61. 1970 Rocket 350 - What's THE BEST valve cover gaskets??
  62. Hard to start 68 Cutlass Supreme
  63. No exhaust?
  64. 71 Cutlass/350 vacuum fittings
  65. Looking forward to summer build
  66. 350 Diesel builds
  67. Q-jet rebuilder recommendation - Chicago area
  68. Olds 350-1980 Cadillac Eldorado
  69. 72 350 kickdown cable need pics
  70. Q-Jet fuel line
  71. 1970 Cutlass S Exhaust questions
  72. Egregious EGR
  73. Im sick of these Big Pro Touring Bully Builders with their big wallets.
  74. Modified Air cleaner question
  75. Piston ID ? with part # and pics
  76. overheating/engine temp
  77. Engine rebuild questions/opinions
  78. 350 balancer question
  79. take a look at the shotgun i wana put in my car
  80. 350 cams
  81. vacuum lines, with stripes
  82. best guide for adjusting a Q-jet
  83. No 'polished' Edelbrock Intake Manifolds??
  84. Q-JET on eBay
  85. What could I potentially run in the 1/4?
  86. Performance exhaust manifolds?
  87. Emissions......../exhaust
  88. Looking for #5 heads
  89. Accelaration/idle problems
  90. factory cams
  91. Replacing intake gasket
  92. Roller Rockers
  93. 72 Cutlass motor question
  94. New HEI distributor for Olds V8 for 55 bucks!
  95. Happy birthday to me...
  96. 260 Manual Transmission Engine
  97. Choke Heat Tube
  98. True Dual exhaust (somewhat long)...
  99. Best Parts for 1971 350 Rocket
  100. What's wrong with the 3A heads?
  101. oil restrictors with high volume oil pump.
  102. Accessory mounting bracket??
  103. Timing chain replacement advice
  104. Serious SBO gearheads only! (LONG)
  105. Oil around spark plugs and smoking engine on 350
  106. 1973 Rocket 350 Build Question
  107. Ideas for a 1964 330 mild build
  108. horsepower question
  109. gjjlj
  110. 307 Exhaust manifolds
  111. 307-403 or something better.
  112. Oil Tests Are Back
  113. engine rebuild cam question
  114. 7A heads, rocker arms question
  115. Looking for #5 heads
  116. Holley 3310 or 4777?
  117. Need Help With My 74 350! Plz Reply
  118. Olds 403
  119. PVC Valve Substitute
  120. at the end of my rope finding a machine shop
  121. Little comp cam kit i found,looking for some hp
  122. Am i getting ripped off? Work done to 350 rocket.
  123. 72 cutlass resto, vacuum line routing
  124. Original 350 What issues to look for?
  125. olds 350 swap
  126. #2 HEADS bad to use?
  127. rocker arm adjustment/ new lifters?
  128. 1967-68 Q-jet/fuel line question
  129. Oil Filter
  130. Spark Knock
  131. 307 Cranks, Coughs but doesn't start :(
  132. Chassis sheet metal paint on liner?
  133. What do i need to install autometer gauges?
  134. My workhorse keeps dying help!
  135. gas tank?
  136. Cleaning up the bay,what to remove?
  137. Doing full exhaust,what mufflers?
  138. Bolting a holley on??
  139. Oil Question
  140. 72 cutlass dieseling
  141. Square primary tubes?
  142. new to forum - hello- lookin for info
  143. belt squeel
  144. Newbie here Just Got a cutty,dont know wh!at it is and im lookin for some juicy juice
  145. Edelbrock 1406 accel. pump
  146. SBO engine weight
  147. #2 heads on a 75 350 block?
  148. 64 330 waterpump question
  149. Carburetor for 215 cu
  150. Head ID??
  151. 350 smallblock needs juice
  152. exhaust manifold
  153. olds heads
  154. 72 cutlass s 350 rebuild
  155. motor noise
  156. Couple pics of the 350
  157. olds 350 to caddy 368 swap
  158. coil bind
  159. 350 Rocket Build
  160. 350 diesel
  161. olds 403 stroker
  162. Any input on engine specs/upgrades PLEASE. I'm a NEWBIE
  163. '72 350 oil sending unit.
  164. '72 exhaust manifold
  165. 64 330 pulleys and accessory brackets
  166. Fuel lines, where does return line go?
  167. buick to cadillac engine swap
  168. Oil return from heads and lifter gallery
  169. Weird Exhaust Manifold on my 1967 330
  170. 350 rocket
  171. 455 c head milling
  172. block girdle
  173. Car not really warming up
  174. Eagle SBO 3.75 Crank
  175. olds 4a heads
  176. how to adjust idle air bleed screw in airhorn of carburetor 307 olds v8
  177. 77 350 head swap
  178. Correct 64 330 air cleaner decal
  179. 71 Cutlass Emissions
  180. what engines exhaust manifolds interchange with a 307
  181. 350 cid varnish problem
  182. 350 block help please
  183. 350 diesel for my 69 cutlass ????
  184. 72 olds 350 7a heads
  185. olds crank
  186. olds 403
  187. port and polish
  188. Questions on the motor I just rebuilt
  189. Cam gear
  190. 350 Diesel Block
  191. 350 Performance Cam
  192. Question on oil pan
  193. budget 350
  194. which is better 403 or 350?
  195. 350 crankshaft pulley torque specs says 315 ft lbs in manual??!!??
  196. Casting # F and a backward 3
  197. Keep the EGR Valve or not?
  198. 350 with a little more juice
  199. Reco: Intake, carb, HEI, headers
  200. What's Going On?
  201. Cracked head, blown gasket, cracked pan 1978 98 diesel
  202. 57 Olds headers
  203. gas tank vent pipe
  204. 371 vacuum advance
  205. Headers
  206. cracked block
  207. Intake manifold
  208. big block heads on small block
  209. Diesel Intake question
  210. 72 cutlass timing mark
  211. Stripped out lower waterpump bolt that goes into engine's front cover 350
  212. THANKS!!
  213. Adjustable valve train
  214. Manual Choke??
  215. 1976 350 Serpentine Belt / Pulley swap
  216. Advice on Headers
  217. PCV Valve
  218. 330 intake on 350
  219. 307 Stroker Motor
  220. vacum lines
  221. 403 coolant
  222. Spark Plugs
  223. Rochester 2GC from 72 Delta 350 should i rebuild myself?
  224. Best 350 Rocket Build
  225. #2 heads push rod holes
  226. Another weird problem
  227. snapping noise in head
  228. 403 Stock Intake v.s. Edelbrock 3711/2711 Performer
  229. 403 Cyl head frost plug
  230. engine id help
  231. Weird starting problem
  232. 403 fuel pump return line
  233. Is my Manifold cracked?
  234. 1970 Rocket 350 - Which carb ???
  235. 142 blower
  236. Anyone Familiar with Old Holley 2bbl carbs?
  237. Quadrajet Help!!!!
  238. 400 blocks
  239. CHUCKED 79 OLDS 350 FOR 1972 350
  240. '69 350 Intake interchangeability
  241. 1964 330 photos please....
  242. WTD: Advice on 330 aftermarket intake manifold
  243. Noob question on tranny crossmember
  244. Torque Plating Question
  245. Freeze Plugs on 307
  246. 79 OLDS 350 BUILD UP
  247. OLDS 79 350
  248. 403 heads to 455 heads
  249. 330 $200
  250. Advice on carb, and headers
