Intake manifold
Intake manifold
I have replaced the intake manifold gasket twice now, first time before I dropped the engine in and the second time was yesterday (about 4 months later). The reason I changed it this time is because the rubber section in the front had extruded out of it's mating surface and was leaking. This happened right after I got it on the road and I lived with it for as long as I could. After replacing it again yesterday and driving it today, low and behold it is doing the same thing. I am wondering if this is a design problem and if so how do I fix it, or could it be because I am using an Edelbrock performer intake manifold and it is too close to the block causing the gasket to get squeezed out?
This is a very common problem. The two solutions are to rough up the rails at the front and rear of the block by centerpunching a series of dimples on the rails (for the rubber to "bite" into) or throwing the rubber pieces away and using a bead of RTV instead. I've had good results with the RTV.
Just finished mine for the 3rd time. This time I used the end seals after center punching the end rails and the intake. I also installed the seals to the block with a little RTV the day before to let them set up and not slide. A little RTV on top of the seal.
Used alcohol for my final clean.
300 miles, no leaks.
shamusj
Dec 18, 2014 09:28 AM
svnt442
Jul 17, 2011 04:43 PM
