Intake Manifold can I use '68 400 4bbl intake on my '67 E block?
Old Dec 18, 2014 | 07:35 AM
shamusj's Avatar
My '67 manifold has a few cracks in it….my '68 looks clean.
Just want to make sure everything will mate up- they look to be the same minus the choke area (depth of hole ).
THanks
Old Dec 18, 2014 | 07:40 AM
Aside from the choke coil, as you note, they should be functionally the same.
Old Dec 18, 2014 | 07:59 AM
tru-blue 442's Avatar
Old School Olds
You will also be able to use a thermal ported vacuum switch with the 68
if you wish. It will have the provision for it.
Old Dec 18, 2014 | 08:31 AM
Oldsmaniac's Avatar
Or have a port for an aftermarket temp gauge....
Old Dec 18, 2014 | 08:44 AM
Old School Olds
This is true, have one of those available too!
Old Dec 18, 2014 | 09:28 AM
Octania's Avatar
Any such intake will do.
Maybe move to electric choke and forget the remote coil?
If your intake is '662 J casting I could maybe trade a later 70-72 casting for it. I make the J into '69 H/O J-405233.... you can use ANY intake, I can only use J-398662.
PAULIE
Jan 21, 2023 03:23 PM
240 Gordy
Jan 28, 2014 03:37 PM
cts-v
Aug 30, 2013 09:22 AM
Gaz Hog
Apr 22, 2010 07:49 AM
Gaz Hog
Mar 31, 2010 07:21 PM
