PVC Valve Substitute
Old Feb 3, 2010 | 06:08 PM
apachemobile's Avatar
Hey all, a nice easy question for ya'll. Didn't even consider the PCV valve when ordering parts, but fortunately the Edelbrock Signature Series comes with the openings. My question is do I need to buy a specific PCV valve or will a breather on one side and a breather with a nipple for the vacuum hose hooked up to the carb perform the same purpose? Is that overkill, will just that and an oil fill plug work?
Attached is the breather with the nipple.
Thanks for the clarification.
http://www.jegs.com/i/Edelbrock/350/4410/10002/-1
Old Feb 4, 2010 | 10:14 AM
If your valve covers come with openings for the PCV and breather then I suggest you run a PCV valve. This should be the PCV valve you need:
http://www.summitracing.com/parts/FRM-FV112/
Old Feb 5, 2010 | 04:59 PM
Thanks for the reply. Called Edelbrock, which I should have done before ordering the part. Oh well another extra part laying around. Thanks again all.
krauser65
Mar 18, 2015 09:56 AM
chrisn0883
Feb 21, 2015 04:03 PM
The Bug Man
Aug 27, 2014 12:36 PM
70Cutrag
Suspension & Handling
Jul 3, 2014 11:10 PM
Chuck_66
Feb 23, 2012 09:34 PM
