bearly turns over
Old Mar 16, 2010 | 06:25 AM
stingger68's Avatar
bearly turns over
i got a 68 cutlass and it sat for a few year after a rebuild. so for i have got a new starter and new battery and still it bearly turns over at all. any ideas? its a 350
Old Mar 16, 2010 | 07:13 AM
Lady72nRob71's Avatar
Jamesbo - this "bear" thread's for you!
(He is the resident CO bear expert.)
How do the battery cables look? Look closely at the ends.
Is the negative cable securely connected to the engine block? Paint removed from area where the cable attaches to?
Was the starter shimmed correctly upon installation?
What is the condition of the engine - has it run before after rebuild?
If never run after rebuild, did you squirt some oil in the cyl. bores before attempting to start?
Old Mar 16, 2010 | 08:17 AM
citcapp's Avatar
If the engine has not run for a few years. Pull all of the spark plugs a pour a little Marvins mystery oil in the cylinders and turn over by hand with a breaker bar and socket. This should help free things up. Check all of the ground cables, make sure the ground strap from the engine to the negitive battery terminal is good, also check the bonding strap from the engine to the body and make sure it is installed both are common problems.
Old Mar 16, 2010 | 09:54 AM
70 cutlass s's Avatar
I would get the engine to top dead center and pull the dist. out and prime the oil pump. When put it back in make sure your timing is right.
Old Mar 16, 2010 | 10:25 AM
stingger68's Avatar
starter shimmed correctly, but i see that the the negative cable is connected to the fender bolt not the block. all ends look new. ill switch the ground to the block and see.
lol and sorry about the bear lol
Old Mar 16, 2010 | 10:40 AM
Looks like ya'll beat me to it. I'm still in a thicket look'in fer my lob wedge w/o much help from the bear.
Old Mar 16, 2010 | 10:44 AM
That should be your problem. I have experienced that issue before.
Best of luck!
Old Mar 16, 2010 | 10:53 AM
Bluevista's Avatar
Registered
Sounds like your problem, not much of a path to the block/starter from there. You should see a difference.
The bear went over the mountain with the lob wedge to see what he could see.
Speaking of bears... Tiger's going to be playing again, golf that is.
The gallery chatter is going be great.
Just a cough and he threw a fit before.
Poor ol' Tiger.
Old Mar 16, 2010 | 01:30 PM
stingger68's Avatar
thanks that was it. turns over like it should now. thanks
XMWZ001
Drivetrain/Differentials
May 19, 2012 06:54 AM
442much
Feb 10, 2011 10:27 PM
Lady72nRob71
May 22, 2010 06:46 AM
jmlondon
Dec 8, 2008 08:13 PM
jaco
Jan 28, 2007 12:54 PM
