snapping noise in head
Old Nov 1, 2009 | 08:55 PM
thorpedo91's Avatar
There seems to be a consistent snapping noise in my driver side head. I'm assuming there is something wrong with one of the valves. It speeds up and slows down with the rpms. I am gonna take the cover off tomorrow to try to get a look at it, but i figured i would come here first if any of you know exactly whats wrong, so I can be prepared for it.
Old Nov 1, 2009 | 09:24 PM
BIGJERR's Avatar
I bleed Oldsmobile
Snapping?? MMMMMMMM.............or maybe a collapsed lifter and a pushrod hitting a rocker arm??
Old Nov 3, 2009 | 04:45 PM
thorpedo91's Avatar
pulled off cover and everything seemed to be pretty tight and well oiled. lifters and push rods were good. could it just be a valve that is not seating right?
Old Nov 3, 2009 | 05:19 PM
BIGJERR's Avatar
I bleed Oldsmobile
Fire it and see were its coming from....Just dont run it for long,Or try the broomstick trick.....
Old Nov 3, 2009 | 05:24 PM
Warhead's Avatar
Check all of the bridges. It may be hard to spot, but I will lay odds that you may have one that snapped.
It is best to unbolt them to see, only unbolt when the cam lobes are NOT on lift for that pair of rockers you are removing.
Jim
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
sully
Brakes/Hydraulic Systems
Mar 30, 2007 11:26 AM
