PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31
  1. Worn out throttle shaft bushings => high idle?
  2. Secondary Carb Adj. spring replacement?
  3. Pulling engine
  4. vacuum line replacement
  5. My 350 has two different # heads on it??
  6. Procomp vs. Edelbrock
  7. No oil to valve train.
  8. Cooling issues and radiator recommendations
  9. 1971 cutlass convert. 350
  10. Ebrock heads on a sbo 90% street car?
  11. Getting a constant "code 41" on GM [FIXED]
  12. Help! Bolt stuck in intake manifold
  13. 330 Engine ID
  14. 307 and weird noise!
  15. vapor lock
  16. Vacuum/timing/overheat
  17. What is this part called?
  18. Belt sizes
  19. throttle cable linkage opinions
  20. 350 sounds like a diesel ?
  21. 307 wont stay on...
  22. got rid of the computer controlled carb and dust. now getting 10 mpg
  23. 350 Olds in a 1965 Chevy Nova
  24. Rockers vs pushrods
  25. Header clearance problem
  26. 1976 Cutlass 350 mods
  27. New Timing Set Problem
  28. Choke coil
  29. need help going in right direction
  30. Here is a small block intake that doesn't exist!
  31. 68 cutlass died when hit bump
  32. 78 cutlass 260 4.3l rebuild
  33. SBO Stroker build
  34. cam kit???
  35. Getting my heads milled?!
  36. 1970 350
  37. Surging under WOT
  38. extreme bogging, stumbling and stalling quadrajet E4MC
  39. Limiting the HEI mechanical advance
  40. Headers?
  41. 69 Cutlass dying while driving
  42. Quick question to verify...
  43. Electric fuel pump
  44. Smokey the Oldsmobile Bear !
  45. Missing on one or two cylinders
  46. 215 Four Barrel Carb
  47. My 72 442 with 350 and TH400
  48. 83 3.8 Need help with vacuum lines
  49. Intake Manifold Question
  50. What kind of heads do I have??
  51. 215 question - Newbie
  52. Factory 2bbl settings for 350
  53. 350 Performance build seem way underpowered
  54. scary moment need help
  55. 350 Stroker build
  56. Intake Gasket style, need advice
  57. SB: Thoughts on Power Level for Transmission Rebuild
  58. my newish 307 thought id share .
  59. burning oil
  60. calling guy's with good advice on o.e. intake gasket issue
  61. piston id
  62. 330 Rochester 4Jet TV Bracket
  63. Oldsmobile 215 pushrod length-valve train noise
  64. 66 cutlass 330
  65. Holley to Quadrajet swap 350 SBO Edel 350T
  66. Olds 403 Build
  67. small block intake
  68. intake swap
  69. W31 Intake and Aluminum Heads
  70. 67 330 exhaust manifold gasket replacement.
  71. 350 olds lower pulley and balancer
  72. 69 350 #5 Heads
  73. 69 olds 350 color ...help
  74. Olds 307 timing chain
  75. Popping through carb on heavy accel from stop
  76. 350 across the garage floor
  77. Ignition Timing
  78. Coolant in Oil headache..need a little advice!
  79. Ugh
  80. 350 Exhaust manifold gaskets
  81. 350 downpipes
  82. #5 head value
  83. 805 newbie (engine stand)
  84. Connecting Rod Bolt help.
  85. Carb help
  86. Disturbing the distributor
  87. What type of carb to get
  88. piston ring confusion.
  89. Trans and drive shaft
  90. please help me out
  91. Gas boiling in the fuel pump
  92. Need to find 330 valves!
  93. Spark Plugs
  94. 3rd gear bogs at WOT...advice to troubleshoot please??
  95. hot ROD
  96. Correct cam and clutch
  97. Should I grind away this metal....
  98. 350 block
  99. Chicago area engine rebuilder
  100. SBO Headers
  101. to straight pipe, or not to straight pipe?
  102. 69 Cutlass Carb
  103. Best Setup For 350?
  104. '70 350 into '79 GMC (was 350 Diesel) help
  105. ignition coil question
  106. headers
  107. understanding cams
  108. 7111 intake
  109. 350 rebuild!
  110. Oil Smell under acceleration
  111. When will it end!!!!!!!!
  112. Vac Advance / Idle Questions
  113. Cam choices
  114. Engine cranks, no start, fuel flows
  115. stuck head?
  116. Open heart
  117. Yelp! Meeee
  118. Flowtech SBO Headers?
  119. exhaust leak
  120. car stalling when ac is on
  121. Carb identification
  122. Exhaust help
  123. Wont idle/stay running after sitting for over an hour
  124. 1956 crossover pipe for Super 88
  125. Headers!?!?
  126. carburetor
  127. Exhaust help!!
  128. High RPM Backfire/stumble/loss of power
  129. vacuum hoses
  130. Hot air choke tubes,and gasket
  131. Fuel Pump Leak
  132. Headers 72 supreme column shift AT
  133. 330 low compression cam
  134. 350 v8
  135. What carb/intake for 67 330 C/S
  136. Random Oil Leak
  137. High hp smog legal build. 87 wagon.
  138. Piston clearance
  139. Need accessory photos
  140. Won't start when cold
  141. knock knock, whos there?
  142. Code/stamp on heads, 67 Cutlass Sup 330
  143. Is this intake any good?
  144. 67 Cutlass 330/ which carb
  145. Non Adjustable valve train setup
  146. Question about my 350 olds
  147. Helmholtz vs. Drone
  148. Stallinng out, HELP!
  149. 350 face lift
  150. Pulley issue
  151. my 72 350 rocket
  152. Which Sealant Do You Prefer?
  153. power steering pulley alignment
  154. 2 Barrel Carburater loose
  155. Olds 215-Why is this linkage spring here? Mine's missing
  156. Plumbing fuel system
  157. Edelbrock Intake 3711 vs 7111 224/230 Duration
  158. Help with Engine Temp
  159. 350 R-code little performance
  160. BACKFIRING help
  161. Where to find manifolds?
  162. Manifold
  163. 1964 330 ci engine parts applacations
  164. trouble finding headers
  165. need help deciding the best exhaust!!!! HELP
  166. 71 Olds Cutlass downpipe question
  167. 7A Head Identification
  168. oil leak
  169. Ran into trouble guys....
  170. How to tell when harmonic balancer has moved-breaking down
  171. 73 Omega 350 upper and lower hose about same temp.
  172. Olds 350 Powered Firebird
  173. No oil coming to rockers
  174. Opinions welcome! SBO street/strip build
  175. Identifying High Compression 330
  176. Comp Cams Hyd. Roller Lifter and Edelbrock 3711 Intake?
  177. Opinions on valve covers
  178. 72 cutlass hot start problem, tried almost everything!
  179. Need help with Intake, Cam and Carb on a 350
  180. 1970 350
  181. Correct clamps for bypass hose?
  182. Overheating or a bad reading?
  183. Olds 215 Initial timing setting with a non-stock cam
  184. 324 ballast resistor
  185. Odd burning smell
  186. Small cam for a stock 350
  187. valve pan holes 87 olds
  188. Can I use this fuel-pump on my 330 without AC??
  189. 303 Rocker arm ratio
  190. 330 Engine identification.
  191. Engine #'s
  192. Oil gusher
  193. Head and Intake Gaskets - 1971 Cutlass
  194. 85 Cutlass Supreme 403
  195. Should I get a bigger carb?
  196. 355 SBO rebuild
  197. Spark plug gap for 68 350 w/ Pertronix?
  198. 330- Bore or not?
  199. Carb Jet sizes and gullible old me.
  200. 350 build
  201. Is it possible to remove oil pan while engine is still in car?
  202. Ugggg.another dilemma
  203. final words
  204. Bushings
  205. End seals
  206. Rocket 350 ugly sight
  207. oil pressure sender size???
  208. *VERY* Small Block Olds
  209. 307 timing adjustment
  210. 5A heads
  211. Headpipes
  212. Vacuum Leak or Normal noise?
  213. 350 oil pressure. (newb questions)
  214. 1968 Olds Cutlass 350 4 Blade Fan
  215. Flowmaster System
  216. Correct GM Belts
  217. 324 Olds Rocket
  218. Timing help.
  219. 1967 oldsmobile engine color and air cleaner color
  220. What engine?
  221. Can you put bb block heads on a sb?
  222. Edlebrock Performer 350 intake
  223. Short Water Pump Cross-Fit Autozone
  224. olds 403
  225. headers swap 455/350
  226. 324 Coolant Leak
  227. Ignition upgrade questions
  228. Torque Specs for Cam
  229. Cant seem to catch a break...uggg.. power steering problems...
  230. lazy 330
  231. Set of #5 heads
  232. 307 Alternator Bracket question
  233. Tightening down distributor causes engine miss and idle speed drop.
  234. Compression readings... What do you guys think?
  235. 307 overheating at highway speeds.
  236. Aftermarket Motor Mounts
  237. swapping heads
  238. Exhaust question
  239. Q-jet fuel feed questions
  240. verify valve timing/intake leak
  241. #4 heads?
  242. The time has come! now critique my setup please
  243. Thought's on roller valve trains...
  244. Total "Mound"ello of bull****
  245. Advice on Exhaust
  246. I want more giddy up, but how?
  247. 324 Manifold (98 Holiday Coupe)
  248. I really like my new Combo!
  249. 1964 Oldsmobile Cutlass 330
  250. Quadrajet vacuum help!
