What kind of heads do I have??
Old Jul 7, 2012 | 09:32 AM
Fastback71's Avatar
So i tried looking for the casting number towards the front of each head but the alternator bracket and A/C bracket are completely blocking my view on both sides. So i went to the driver side Head and in the center of the head the only casting numbers I could see was 409 147. Can this tell you if they are 5, 6, or 7 heads?
another quick question.... I noticed I have pcv on both valve covers thats linked to my air filter housing then a tube down to the passenger exhaust manifold. does this mean i have EGR or it just positive crankcase ventilation to help it breath/vent a little better? and if i replace the filter housing to after market can i just get away with putting aftermarket breathers on both valve covers for ventilation?
thanks for your time
Old Jul 7, 2012 | 09:37 AM
allyolds68's Avatar
7's or 7A's, can't help on the other question
Old Jul 7, 2012 | 09:44 AM
Fastback71's Avatar
is the 7 or 7A worth keeping if I just wanted to port them a little bit and match them up to a good cam/intake/carb combo?
Old Jul 7, 2012 | 11:42 AM
Fastback71's Avatar
well son of a bitch! i wiped off some old grease/oil front the front of the head and got the right sunlight and looked between the cracks and low and behold i have #7 heads lol. time to do some research...
Old Jul 7, 2012 | 09:37 PM
ihengineer76's Avatar
The #7's are a good head. If you are going to port them anyway, there is no reason to switch to a 5 or 6. Most will argue that there is little flow difference between them assuming valve size is the same. These heads have the same size chambers as 5 and 6 also. If you are switching cams, adjustable rockers are a nice upgrade as well.
Old Jul 7, 2012 | 09:53 PM
Fastback71's Avatar
good stuff thanks for the info!
snylften
Mar 31, 2014 02:06 PM
gardizzle86
Aug 7, 2011 10:09 AM
oldzy
Jun 8, 2011 06:49 PM
Dragonist
May 14, 2011 11:29 AM
GoldOlds
May 20, 2007 09:17 AM
