What kind af carburetor do i have?
Old Feb 5, 2014 | 12:46 PM
snylften's Avatar
Hello again.
I try to find out what brand and model my carburetor is. The only numbers i found on the side of the carb is 2770 and 2916
I would be very pleased if someone could help me find more information about the carburetor. (watch the pictures)
many thanks
Old Feb 5, 2014 | 12:53 PM
coppercutlass's Avatar
Chevy budget Olds powered
Look those numbers up in the edelbrock catalog. Looks like an old edelbrock carb or an old carter carb which is the same as the edelbrock from a design stand point but just newer and re branded with a few modern touches. Most likely an old carter carb.
Old Feb 5, 2014 | 01:35 PM
It looks like a Carter AFB.
Old Feb 6, 2014 | 11:33 AM
snylften's Avatar
Today i took the carb of the engine for a closer look. And you were right, it is a Carter AFB. The numbers i found on it is 2J3 9635S. So i wonder what those numbers stand for. I did some googling but no answer them yet.
Then i notice that i have damaged the pin that makes the fuel goes in the carb.
It is nolonger straight. So when i push the gas is doesnt pushes down the hole, it bends forward instead. Watch the picture. My guess is that i have to replace that pin/pushrod thing. I think it is a plastic pin or something. What do you call that? Sorry about the poor explanation.
Old Feb 6, 2014 | 11:57 AM
Unless the carburetor is original to the engine I think buying an edelbrock carb might be cheaper than a rebuild and its essentially the same thing.
Old Feb 6, 2014 | 12:42 PM
The plastic pin is called the accelerator pump.
Here is a kit for your carb:
http://www.oreillyauto.com/site/c/de...2259&ppt=C1980
Old Feb 6, 2014 | 12:49 PM
CQR's Avatar
CQR
That looks like excessive wear in the bore of the airhorn where the pump shaft goes thu. You may not be able to get the accelerator pump to work tight even after an o/h.
Old Feb 12, 2014 | 10:41 AM
49olds 88's Avatar
afb dang god carb. I had 2 fours on a389 in a 53 ponatic back in the 60,s and have 2 on my 49 olds. Does not flood as easy as a holley, and is easy to rebuild
Old Mar 31, 2014 | 12:47 PM
snylften's Avatar
hi all again. I was thinking to buy a Edelbrock performer 600 cfm 1405. from a friend of mine. But is it gonna fit on my intake? And how is my engine respond with that carb instead of my Carter carb?
Old Mar 31, 2014 | 01:06 PM
billmerbach's Avatar
major noob
Don't your carb is a 625 cfm lol plus a good rebuild on it and it'll last a gooooood loonmmmggg while
Old Mar 31, 2014 | 01:52 PM
Let's back up. The carb you have is an aftermarket Carter AFB that was retrofitted to your car. The die cast adapter plate is a tipoff that this is not the original carb (which would have been a Quadrajet, since Olds never used an AFB from the factory. The electric choke is also an indicator of the aftermarket AFB. The Edelbrock carbs are just re-badged Carter AVS carbs, which are air-valve versions of the AFB. You can rebuild the one you have, replace it with an E-brock, or get a correct Qjet for your application.
Old Mar 31, 2014 | 01:58 PM
I'm guessing this carb is on the 70 Cutlass in your picture? If so the car originally had a Rochester Quadrajet carb, which is a spread bore. Your intake shows how much bigger the secondaries are. You have to make sure the carb you buy is for a spreadbore. Most are not ( primaries and secondaries are the same size).
Old Mar 31, 2014 | 02:06 PM
The AFB is not a spreadbore, which is why you see the adapter plate in the photos.
Fastback71
Jul 7, 2012 09:53 PM
gardizzle86
Aug 7, 2011 10:09 AM
oldzy
Jun 8, 2011 06:49 PM
yeahbuddy
Jun 1, 2010 05:38 AM
Oldsguy
Nov 21, 2008 05:44 AM
