Pulling engine
Old Aug 7, 2012 | 08:36 AM
XTREMEGSXR's Avatar
Pulling engine
What is the best points to hook the chain to when pulling engine & trans together?
Old Aug 7, 2012 | 08:39 AM
I use a motor plate on the intake manifold. There are also 2 lift brackets on a lot of the motors. Or you can use 1 bolt in the front and 1 in the rear on opposite sides of the heads.
Old Aug 7, 2012 | 08:51 AM
ah64pilot's Avatar
Lift plate is cheap, covers the intake manifold up, and makes installation much easier than chains on opposite heads. Go get one, they're less than $20. Make sure to get grade 8 bolts as long as will fit inside the intake and still tighten up against the plate. I think I use 5/16" X 1" on the last one...it's all dependent on the intake.
Old Aug 7, 2012 | 09:14 AM
GAOldsman's Avatar
"Car"mudgeon
This is also very helpful when pulling both
$24.99 on sale here
nj_cutlass72
Oct 21, 2012 10:08 PM
nj_cutlass72
Oct 2, 2012 08:42 PM
Hawk1061
Jun 16, 2012 07:32 AM
442craig
Apr 10, 2012 12:22 PM
zodiacblueS
Aug 12, 2011 02:43 PM
