Pulling '68 442 engine
Old Mar 27, 2012 | 10:19 AM
442craig's Avatar
Hi Guys,
I'm sure this has been covered before. I am pulling the engine in my 68 442. I have it ready to go. I am pulling it with the Trans in tact (TH400) Question is, do I need to remove the Transmission cross member to clear the tunnel?
Also, I have the intake manifold off, where do I connect the hoist? Do I need to put it back in?
Craig
Old Mar 27, 2012 | 12:05 PM
Rusty Boltz's Avatar
Yes, you will need to remove the crossmember to allow the rear of the tranny to drop down. I usually use the bolt holes located at the front and rear of the heads to attach the chain to for pulling the engine. As a rear hole on the passengers side and a front hole on the drivers side.
Old Mar 27, 2012 | 12:52 PM
442craig's Avatar
Thanks!
Old Apr 10, 2012 | 07:21 AM
442craig's Avatar
Ok, so getting close to pulling the hulk out. I got a 1 ton (harbor freight) hoist (actually impressed with it and it was only 99 bucks!) I bought an engine load leveler. It came with the chain. Any ideas how to bolt it to the engine? It has four links.
Thanks!
Craig
Old Apr 10, 2012 | 09:28 AM
allyolds68's Avatar
Thanks!
Craig
There's a 3/8" threaded hole on each side of the heads at the top. Most people use those
Old Apr 10, 2012 | 11:27 AM
442craig's Avatar
Yeah but what to use to hook the chain to it. Bolt with a few fender washer so it wont slip off? Any suggestions?
Thanks!
Old Apr 10, 2012 | 11:35 AM
allyolds68's Avatar
Thanks!
A 3/8" bolt and washer. You won't need a fender washer unless it's huge chain. It really doesn't weigh that much. Many people pull motors with a carb plate. I think those are four 1/4" bolts
edit: (use grade 5 or grade 8 bolts)
Old Apr 10, 2012 | 12:22 PM
442craig's Avatar
I'll give it a shot, the intake manifold is off the engine so
I'll have to got the head route!
Thanks!
nj_cutlass72
Oct 21, 2012 10:08 PM
nj_cutlass72
Oct 2, 2012 08:42 PM
XTREMEGSXR
Aug 7, 2012 09:14 AM
Hawk1061
Jun 16, 2012 07:32 AM
zodiacblueS
Aug 12, 2011 02:43 PM
