swapping heads
Old Apr 10, 2012 | 08:29 AM
Finn5033's Avatar
swapping heads
Could I put the heads off of a 72 350 onto a 77 350? Would it make a noticeable difference? I am using the intake and carb from the 72 on the 77 already. Just wondering if it would be worth the time to use the better heads too?
Old Apr 10, 2012 | 03:27 PM
bigD's Avatar
what heads are on your '72? the '77 heads are most likely #8's with 80 cc chambers...
Old Apr 10, 2012 | 04:39 PM
... And the '72 heads are most likely 7A's with 64-ish cc chambers.
If I recall, the '77 motors had 14cc pistons, while the '72s had 24cc pistons.
The 14cc pistons of the '77 block plus the 64cc heads of the '72 block should result in a compression ratio of about 9:1, much better than the 8:1 of either the '77 or the '72 engines.
(Check me on this: 350 dish volumes were 0, 6, 14, and 24cc, for 10.5:1, 10.25:1, 9:1 [or 8:1 in 1973 and later], and 8:1 [in 1971 and '72 only] respectively, right guys?)
Old Apr 11, 2012 | 05:30 AM
bigD's Avatar
i would say yes then it would be worthwhile. your pistons should be either 6 or 14 cc so that should give you a good bump in compression.
Old Apr 15, 2012 | 11:18 AM
Warhead's Avatar
If you truly have a 77 block (casting 554964) that you want to install 7a heads on, you would be pulling off 3A heads, which have a 75cc chamber with 1.875/1.5 valves.
#8 heads came in 73-76 350 engines and have 7/16ths head bolts, your 3A heads will have 1/2 inch head bolts. The 7a heads will have ~69cc chamber at best (not a 64cc chamber), with a larger 1.56 exhaust valve, using the early 7/16ths head bolt.
You will have to have the head bolt holes opened up with a 17/32 drill bit in a drill press or a mill to use the #7a heads on a 77 block. Do not try this with a hand drill.
If you use standard head gaskets, you will gain around 1/2 a point of compression using the stock pistons.
Old Apr 15, 2012 | 11:39 AM
oldsmobiledave's Avatar
SBO head CCs
1972 sbo heads do NOT have 64cc chambers. The only factory head with 64cc chambers is the 1967 #4 heads.
The #5, #6, #7 incl the small capital A in 1972 are all measure 68-69ccs unless the heads have been milled.
You will also have to drill out the early heads for the larger head bolts required to bolt them onto the later 350 or 403.
camdon454
May 17, 2014 07:23 PM
jmac69cutty's
Oct 31, 2008 12:28 PM
59-59-59
Apr 16, 2008 09:13 PM
dhoopty
Drivetrain/Differentials
Apr 16, 2008 09:45 AM
oldstay
Mar 6, 2008 02:48 PM
