I want more giddy up, but how?
Old Apr 4, 2012 | 10:14 AM
rhett838's Avatar
68 Cutlass S Convertible
I'm just looking to add a little HP to my 68 olds 350 engine with a turbo 350 trans.
I've been looking over some threads, but now I'm more confused. I'd just like to hear a general consensus.
I already have the Edelbrock carb on the car, but I'm thinking a manifold, a cam, and some headers will get me what I'm looking for.
So what should I go with? The Edelbrock Performer series (2711 intake, 3712 Cam), or the Performer RPM Series (7111 intake, 7112 Cam)?
Also is a valve spring change necessary with a new cam?
If I made this change, what else would I have to add?
I'm a You Tube mechanic, but on my 69 I changed my manifold with success (I think). Are these jobs I can do myself, or should I pay someone to do it for me?
Changing a cam doesn't look that bad...on You tube.
Thanks!
Old Apr 4, 2012 | 10:37 AM
Lets back up a bit here! How fresh is your motor? I'm assuming outside of the carb change its relatively stock?
Old Apr 4, 2012 | 10:44 AM
hookem horns's Avatar
May get more bang for your buck with gearing if you currently have tall highway gears (2.xx), especially around town. A 3.42 rear end and shift kit really wake up my car with a 350. Still not too bad on the highway with around 3000 rpm @ 70mph.
Old Apr 4, 2012 | 10:54 AM
rhett838's Avatar
Yes - Everything is stock.
I want to leave the gears alone a this point, primarily b/c of funding.
The other caveat is I don't have the car, and I've never even seen it. It's getting restored right now in AZ.
The previous owner bought it from the original owner, and he said the oo bored it out and had it rebuilt, but not recently, but there's no paperwork on that claim.
My problem is I don't have possession of the car, and I won't until June. So I'm thinking too much!
LOL!
Old Apr 4, 2012 | 11:05 AM
jpc647's Avatar
If you change your gears, make sure you buy a new gear for the speedometer cable, otherwise your speedometer will rear crazy high.
Old Apr 4, 2012 | 01:56 PM
jag1886's Avatar
What are you starting with a 2 or 4 BBL engine.
Old Apr 4, 2012 | 02:02 PM
rhett838's Avatar
There's already a 4bbl edelbrock carb on it, but I don't know what choke is on it and I wont until I get the car.
Hmmm. Now that I think about it I wonder if there's a 4bbl carb running on a 2 bbl manifold?
I'm going to hAve to call them
Old Apr 4, 2012 | 03:08 PM
Rich Kinsley's Avatar
I think I'd be prone to wait till I had the car before making any earth shaking changes. Too big a cam without a high stall torque converter and a higher numerical (aka lower gears) rear gear set-up can destroy the bottom end and cause the car to be very lethargic and the gas mileage will also suffer.
An Edelbrock Performer RPM is the best all around manifold if you want to run it hard at least occasionally. The carb size important too. If it's a 500cfm it may suffer on performance too. The springs need to be checked to see if they are still suitable with the cam you chose. If your lift is increased too much it can bind the springs and bend or break pushrods, etc..
If you are doing it yourself, which is my preference, be sure to work with a good shop for your machining and they'll help you design compatible components. Just throwing parts at an engine can be counter productive.
Have fun!
Old Apr 4, 2012 | 03:11 PM
jag1886's Avatar
Let use know when you get the car and throw up some pictures of what on there now that would help.
Old Apr 4, 2012 | 03:21 PM
rhett838's Avatar
That's good advice Rich! I did plan on waiting before I got all crazy on it.
I didn't know that you'd have to get a sturdier torque converter if you changed your cam. It makes sense though, and it sounds like something out of my league.
Old Apr 4, 2012 | 03:25 PM
The torque converter stall speed needs to match the cam requirements. The cam maker will recommend a minimum stall at least. They can really make or break your overall performance and streetability.
rhett838's Avatar
Jag - Below is a link of the ad and tons of pics.
This is all I got right now...
http://www.oldsmobilecentral.com/201...-olathe-ks.php
Old Apr 4, 2012 | 03:46 PM
It looks to be a good candidate. Are you good with the tools? I would encourage people with an interest and not enough knowledge to sign up for auto shop classes at your local city college. These can be inexpensive and allow you to use the shop facility and equipment with supervision to let yoou find out how to do it. I took all the shop they had in CA at Saddleback College in the early 70's and got to bore my own engine, etc.. I have used this knowledge often to have fun with my toys and occasionally it saves my neck :-)
Have fun with your toy.
Old Apr 4, 2012 | 03:58 PM
rhett838's Avatar
Another great idea Rich!
Old Apr 4, 2012 | 05:06 PM
Let's wait until you have the car and see the condition of the motor first. If you beef up the top end you will strain the bottom end and that usually leads to other problems.
Old Apr 5, 2012 | 05:10 PM
jrmandryck's Avatar
I would not suggest a cam swap or rear gear swap if you aren't extremely confident
jrainwater73
Aug 18, 2015 11:43 AM
Oldsragger
Brakes/Hydraulic Systems
Jan 26, 2015 05:28 AM
White_Knuckles
May 19, 2014 09:03 PM
ELECMAN
Nov 20, 2009 07:26 AM
old-mans-mobile
Jul 10, 2007 09:19 AM
