Should I grind away this metal....
Old Jun 10, 2012 | 11:33 AM
boese1978's Avatar
See the small lip on the dual plane divider on the bottom of the butterfly throat holes...shuold I "dremel" this away a bit to smooth it out?
Old Jun 10, 2012 | 11:40 AM
coppercutlass's Avatar
Chevy budget Olds powered
aslong as it's not on the engine it wouldnt hurt it.
Old Jun 11, 2012 | 08:32 AM
Is your spacer on correctly, the divider should run up the center?
Old Jun 11, 2012 | 09:36 AM
Any mismatch like that will cause turbulence, disrupting the flow.
Old Jun 11, 2012 | 10:05 AM
@ oldscutlass I think hid intake is a spreadbore kind so that lip is probably where it starts to widen out for the secondaries would be my guess. I have only seen that with spreadbore intakes and spacers like that.
Old Jun 11, 2012 | 10:24 AM
boese1978's Avatar
The spacer is seated and centered. There are equal amounts of metal on each side, I took the tpicture of the one side for clarity. Spread bore has nothing to do with it, the "devider" is straight and narrow from front to back........
Old Jun 11, 2012 | 11:33 AM
You can, just as Joe say's to smooth your flow. If the divider is raised flush with the rest of the manifold as a true dual plane, I would also run 4 hole gaskets, top and bottom.
72cuttys
Jun 9, 2013 08:03 AM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
oldsw31
Aug 30, 2012 04:13 PM
BStone
25
Aug 14, 2012 09:35 AM
I'amTheBatman
Aug 10, 2012 12:16 PM
