Starter grind
Old May 6, 2012 | 08:45 PM
BStone's Avatar
Starter grind
Have got the beast back out now tha the sun is out and snow if gone.
I have had a starter issue for some time now.
The car will start fine on most start-ups however every 5-6th start I will get the grind of shame. It will do two grinds in a row and then usually will catch and spin on the third attempt.
Have not got into it yet but suspect that this will be a problem with some worn teeth on the flywheel vice the starter itself based on how it always seems to catch after the 2 grinds.
Anyone else go though this yet? If sdo, any pointers/thoughts are greatly appreciated
Old May 6, 2012 | 08:49 PM
I remember meeting you and your car last year. Wondered where you had gotten to. You were looking for those decals on the VCs at the time.
re: starter. You might just have a really weak solenoid on the starter. If you were missing teeth on the flywheel, I doubt you'd even get grinding.
Old May 6, 2012 | 09:24 PM
BStone's Avatar
Hey Allan
Still here but had gone to ground over winter. Have had the olds out a couple of times this year so far. Will be taking it to work tomorrow so will be up around North side
Ack re the grind. Its that ringing noise but probably not a bad idea to take the starter off and have it checked before I do anything drastic.
Old May 7, 2012 | 04:45 AM
m371961's Avatar
With the starter off, turn engine over and look for bad teeth on the flywheel/flexplate.
I have filed or ground them with a Dremel/die grinder in the past to get by, and the ring gear can be replaced if needed.
Also check to make sure the ring gear around flywheel is not lose. Seldom happens, but does occur.
Old May 7, 2012 | 07:35 AM
BStone's Avatar
Forgot to mention its a 67 425. I was looking at the manual quickly and it seemed from the pics that the teeth ring is part of the flywheel ie you have to replace the whole flywheel?
Thanks for the pointers
Old May 7, 2012 | 08:49 AM
Originally Posted by BStone
Forgot to mention its a 67 425. I was looking at the manual quickly and it seemed from the pics that the teeth ring is part of the flywheel ie you have to replace the whole flywheel?Thanks for the pointers
IF you find the flywheel has damaged or broken teeth, yes you pretty much have to drop the tranny to take off the flywheel. You should also have an inspection cover that you'll have to take off to see the flywheel gears. I'm hoping it's just the solenoid on the starter.
Old May 7, 2012 | 06:36 PM
BStone's Avatar
Yeah me too!
If I need to replace the flywheel, will one from a 455 interchange?
Old May 7, 2012 | 06:42 PM
m371961's Avatar
Can't the ring gear around the flywheel be replaced as in other makes?
Old May 7, 2012 | 06:50 PM
Yeah me too!
I don't know. On a guess I would say yes. If no one chimes in here Brian Trick (507OLDS) https://classicoldsmobile.com/forums...=newpm&u=25006 or Richard (Gearheads78) https://classicoldsmobile.com/forums...o=newpm&u=7454 will know for sure
EDIT: BTW if you need a flywheel for a 455? I have one in the shed you can use. Came off a 73 455.
Old May 7, 2012 | 06:52 PM
No.
The important question, though, is whether this car is a manual or automatic transmission.
If it's a manual, it has a flywheel.
If it's an auto, it has a flexplate.
The big difference is in weight and price. Flexplates weigh nothing and are a dime a dozen.
Old May 7, 2012 | 07:03 PM
Originally Posted by MDchanic
No.
It's an auto Eric. Beautiful car too. So it's a flexplate. Does the 455 flexplate interchange with the 425?
Old May 7, 2012 | 07:07 PM
BStone's Avatar
Its an auto Eric. Seems like the flexplates for the 425 are a bit tougher to find?
Edit: Found one on ebay now for $40. Scratch that...US ship only and does not list condition
Old May 12, 2012 | 11:43 AM
If you need that flexplate for the 455 send me a PM. You can have it for 5.00 It's in my shed just taking up space.
Old May 12, 2012 | 02:10 PM
m371961's Avatar
I didn't think the ring gear could be replaced on a flexplate, but it can be replaced on a flywheel, at least if one could be found. At least on a 65 425, as per chassie manual.
Now we know he has a flexplate.
Old May 25, 2012 | 06:58 AM
Russ P in MD's Avatar
I'm more familiar with Camaros, here's a forum thread you may find useful. There is a imbedded document neat the end on shimming instructions.
http://www.camaros.org/forum/index.php?topic=2351.0
Also note the one comment asking if he had the front support brace installed. I've no idea if Olds used these, but on Chevy's they often get lost, and result in extra stress on the starter.
Old May 25, 2012 | 04:56 PM
ziff396's Avatar
I just put a mini starter on mine and thought that I checked the depth and backlash in the teeth correctly. Out of the first 10 starts it only did that on the last. It turned out that the starter needed 3 shims for the teeth to mesh correctly and work without any grind. It only did it once, but that was enough for me!
Old Jun 21, 2012 | 09:05 PM
BStone's Avatar
Still have not managed to locate a flexplate for my 67. Any suggestions as to where I can find one?
Thanks fellas
Old Jun 21, 2012 | 11:21 PM
Ok, I just looked up the flexplate in the GM parts manual. The one for 455 will not fit the 425 apparently. Different part number.
One guy on this site who might be able to help you is John MacNeel. (2blu442) He's in Oregon and has shipped stuff to me here in Edmonton using USPS. Great to deal with. If he has the part, he's very fair on pricing too. Here's a link to his PM https://classicoldsmobile.com/forums...o=newpm&u=2171 If he doesn't have it, Eric (jensenracing77) or Scott (Oldspackrat) or Brian (507OLDS) will likely have one - just that they're in the eastern US and shipping may be more.
Old Jun 22, 2012 | 12:52 PM
Summit Racing carries flex plates, wow they are expensive for a 425 compared to the $40-50 I paid for a SBC.
http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc
Old Aug 13, 2012 | 05:13 PM
BStone's Avatar
Have confirmed that the flexplate has a dead spot.
Anyway to know which flexplate I need? The Summit site has two different converter bolt patterns for a '67 425!
Old Aug 13, 2012 | 05:23 PM
copper128's Avatar
Lt. Buzzkill (ret.)
The ATI #915563 is the only one Summit shows online that will work for your car.
Rocket Racing sells one for considerably less. So does Olds Performance Products.
Old Aug 13, 2012 | 05:56 PM
From what I've read, the flex plate from a 330 will also work. Maybe someone has a 330 sitting around in a parts car?
Old Aug 13, 2012 | 05:58 PM
copper128's Avatar
Lt. Buzzkill (ret.)
Yes, 330/400/425 all use the same flexplate.
Edit: I removed the link to the PRW part. After further review of their confusing description, it appears to be a late ('68 - newer) flexplate.
Old Aug 13, 2012 | 06:07 PM
BStone's Avatar
Thanks for the sites.
Most of these sites seem to list 2 variants - internal and external balance.
The summit 915563 has two diff converter bolt patterns 10.75 and 11.5) for a 1967 with a 425 but both are external balance.
I'll call them up tomorrow and see what they say.
Old Aug 14, 2012 | 08:36 AM
Mikes65's Avatar
I have an original flexplate from a 65 400 in nice shape.
I am on vaca now but I can check it when I get home this weekend. I think I paid 50 bucks on e-bay a while back--I will sell for same if you are interested.
Old Aug 14, 2012 | 09:35 AM
Octania's Avatar
AFAIK all our favorite 65-90 Olds v8's are external balance- thus the weight plate on a flexplate, and the missing chunk on a flywheel.
Ring gear is shrunk onto a flywheel, replaceable. Welded to the flexplate, not a service part. If anyonw knows where to get a MT ring gear please share. I have ONE new one in the garage.
You need any flexplate from any '64 330 thru '67 330, E400, or 425 motor. There should be a vast supply and not too bad pricing.
The 1968+ 350, G400, and 455 flexplate looks the same at 1st glance but cannot be used.
To differentiate: The EARLY flexplates were typically mated to a crank with an L shaped notch- the rust/ dust pattern on the flexplate should have a matching shadow.
The LATE pattern cranks are typically a "C" shaped notch, indicating a cast crank. This is a later flexplate if it has that shadow.
BUT.... There is a late pattern 455 crank with a J shaped notch, and [dammit] a late 350 Nodular crank with an L shaped notch... so an L shaped shadow is not 100% certain an early flexplate.
For mtg to the crank, we have an imperfect hex pattern, thusly:
Early has 1 hole offset about 5 degrees [CW vfr I think]
Late has -2- holes offset THE OTHER DIRECTION.
Consequently you cannot possibly bolt one type flexplate or flywheel to the wrong type crank, w/o major modifications. Which I have done.
SO, as a result of these not quite right on the pts of a hex holes... if you measure the SPACING from hole to hole, you will find that some are Medium, some are Short and some are Long.
EARLY: MMMMSL - 4 mediums [1-7/8" IIRC], and the offset hole causes the adjacent holes to be about 1/8" closer or farther away, so there's one Short and one Long.
LATE: MMSLSL - two of each size.
You can measure any way you like, even a toothpick will do. I go from side to side of holes, which is easier than trying to discern the center of a hole. As long as you use the same method and the same stick, you will get either 4 mediums or 2 mediums, and then you KNOW what type flexplate or flywheel it is.
scooter123
Jun 29, 2014 08:26 PM
henryk8398
Ninety-Eight
27
Dec 13, 2012 04:32 AM
oldsw31
Aug 30, 2012 04:13 PM
I'amTheBatman
Aug 10, 2012 12:16 PM
boese1978
Jun 11, 2012 11:33 AM
