- edelbrock carb dripping fuel
- slow crank
- dualjet 210. 260 and factory 5 speed
- '57 Olds 98 371 with J2 Rebuild - Questions
- 307 to 350 or 403?
- Please help me sort out my vacuum
- #6 heads with 2.00 intake
- 330 4v-9 Year Storage Water Pump Blues
- high rpm popping/breaking up olds 215
- suggestions for 350 in 69 S
- INSPECTIOn
- Backfire or Pop Pop at low held speed 35-45
- Oil Pressure Sending Unit
- Oil Cap ID
- Intake and carb swap
- Oil Pressure Gauge Question
- Help identifying a part.
- 24" or 36" Throttle Cable?
- Empty coolant from block = no freeze?
- Hooker 3901HKR headers
- Darn Track Gear
- 4bl carb
- Carburetor problems :(
- 350 rocket upgrade
- Brackets help!
- new starter options with headers
- Oil pan for 350
- Edelbrock RPM Manifold #7111
- 307 V8 noticed some hesitation during drive today..what could it be?
- Help for 1977 350r olds
- Need vacuum diagram
- Intake/Carb recommendations
- Supercharged small block done
- 1967 330 Carb Linkage Pic Needed
- Exhaust Manifolds
- Cam Choice
- #4 Heads on my 1966 Holiday Coupe
- Dual Snorkel
- Best heads for 350 sbo
- Power Steering Delete on 67 Cutlass Supreme
- Quick Question for the Experienced Engine Builders
- deck height
- Valley pan or head gasket?
- Scary Find, curious how bad this might be
- Starter bracket
- Olds 307 exhaust manifold gasket tips
- Edelbrock 3711 fitting sizes
- 350 Motor Photos and Questions!
- Building my first 350 rocket
- Looking for Recommendations for engine builder/machinist in Hawaii
- 1985 Olds 98 Regency
- 350 build power & economy
- jv748 rear main seal
- My inventory - Not what it is supposed to be
- Machine Work
- Leaking fuelpump
- Stock Intake Manifold
- Understanding camshaft durations
- Heater core/PCV hoses
- Supercharging Vs turbocharging
- Best 4bbl intake / carb combo for rocket 350?
- Preferred Headers / Exhaust for Rocket 350?
- Suggestions for choosing the right Hydraulic Roller Cam
- buncha motor swap questions/G body/AC
- 350 Rocket
- Rocker Arms and Bridges
- Carburetor Pros and Cons
- Motor Hesitation
- milling the heads
- OEM Engine lift loop
- Vacuum test help
- Small block head bolts different sizes?
- Connecting rods
- Carb information
- burning oil.. ideas?
- Frustrated...valley pan gasket
- help please so frustrated
- Machined Cylinder Heads - Install
- 350 Nascar Olds
- carb and intake swap
- carb spacer...
- heat riser on manifold
- 69 350 rebuild vs. 403 questions
- Edelbrock Intake Manifold
- Rocker arm ratios
- Cam suggestions
- Nitrode spark plugs
- How can I improve?
- Engine problems, lost, need help
- 350: original vs rebuilt/modified
- Intake Manifold - Edelbrock 3711
- Rare 260 RH exhaust manifold
- Intake Manifold Identification
- Did my '70 Cutlass come with a fan clutch?
- Olds 330 year Identification
- 1967 330 Lifter knock
- Motor had been purchased, few questions.
- How to identify an original 350 rocket
- Question about Deck Clearance & Compression
- 350 sbo worth??????
- Best combo of aftermarket parts for low end torque
- Aluminum heads
- Choosing the right pistons
- 350 Swap pending?
- olds 350 compression ratio
- wrong top plate and shroud
- Engine pics and distributor question
- SBO Mechanical pump with Edelbrock heads?
- #2 heads 3/8-16 base rocker studs
- 350
- How to produce 500 hp
- Serpinetine systems
- Trying to fire up 350
- Alternative to the felpro full gasket set
- Solenoid assembly
- Considering engine swap
- 13.5 second olds 350 goal
- Helping a engine stay cool
- starter color
- 350 Cylinder Heads - Side Specific?
- Christmas Present for the 70 Supreme
- 267?
- I feel like I have no power
- TDC Questions...
- Oil pickup - face the front or the back?
- 1970 Cutlass Battery Tray & Hold Down Assembly
- Valve Cover Bolts
- 67 330 head id
- Is it worth putting in a cam ?
- Head Bolt question
- Sport comp water temp and intake question
- Sport comp tachometer question
- 1972 Intake on a 1977 EGR block
- 1969 cutlass s
- Fan shroud, Fan cluch removal
- Valve stem installed height
- 1977 Omega with 305 Fuel Pump Help
- 72 Vista Cruiser backfiring through exhaust
- Is these a reasonable carb application?
- Three Angle Valve Job Curiosity
- Shim head gaskets; sealer or no?
- Quadrajet Carb / Options, Suggestions
- Replacement starter? Small block chevy 350
- 1966 F-85 330 larger capacity oil pan
- Exhaust ideas on a 84 cutlass
- Omega Heater Hose Replacement
- 1978 Cutlass No Start Issue
- Oldsmobile EFI System w/Manifold?
- identifying heads
- max timing mark on harmonic B
- Tick Tick Tick Tick
- 67 CS Conv carb help
- thoughts on my sbo?
- harmonic balancer
- new cam / push rod question
- Quick Question
- Quadrajet running rich, need help
- 1986 Q-jet better than 1972?
- to soak or not to soak....lifters
- Car won't start...
- Catch Pan under Intake manifold needed?
- Gasket(s) install question
- Cam...
- 307 Y Cam
- Which head gaskets do I use?
- TDC w/ heads off - 1970 350 Rocket
- Header problem
- 74 Cutlass Supreme dual exhaust original or not?
- chasing threads
- Order of operations...
- Edelbrock Intake Manifold - 350 Olds 5.7L
- Where to find 1/2 inch head bolts with the studs for the AC bracket
- best guess on HP?
- Cooling Olds 350. Radiator options
- 1969 350 won't start
- Changing to a 3.42 rear consequences.
- General Maintenance - Engine and Transmission
- Bolt on EFI, Anyone tried it?
- Argh...Timing Chain
- Got my heads back
- Header install
- looking for front oil seal
- Timing tape
- Stock Rocker Arm Stud Size?
- Rebuilding original 350
- Oldsmobile intakes
- 1993 Engine Rebuild Paperwork - Part Numbers
- 330 hp ??
- Looking for 350 spec/build sheet
- Pulleys and water pump size
- Procedure for installing Rocker Arms/Bridges
- Dual Valve Springs? On a '67 330?
- cam and stall
- Ebay stainless 350 headers
- Purge valve question
- 1965 Olds 330 Rocker Arm Fitment Question
- Detonation question
- Head milling question
- Builder for a virgin 330 rebuild, any takers?
- 1986 Code '9' 307
- Revamping my cooling system
- Smog motor performance
- My chewed up timing gear!
- 350 olds engine for sale
- Head's Up -- American Made PCV Valves Avail at Rock Auto
- Pontiac brackets & pulleys
- Is this normal?
- sbo water pump pulley clearance
- 2-jet Carb jet question
- 1972 350 rocket HEI ignition
- Quadrajet Quandary
- Carb Numbers
- Question about different exhaust manifold shrouds 1968-72 350's
- Need help
- Olds Rocker Arm Questions
- I'm 100% stumped.
- Getting my heads rebuilt
- Timing Mark
- Crossover pipe bolt dilemma
- 1955-56 exhaust manifold questions
- slow crank problem
- Earliest 442 ever made?
- Vacuum Switch / TCS / 2GC Rebuild
- Comp Cam 1441 Rocker Arm Kit (350-403)?
- Thinking about a new carb
- VRV Vacuum Reducer Valve question
- 72 350 rocket
- New OldsRocketParts SBO 6" Rods
- Valve Job upgrade
- Rear Main Seal
- Why does my motor not have a dipstick
- 403 Toro Pass-side exhaust manifold
- engine stand seems bouncy
- 371 - thread size of manifold bolts
- Help! Please
- Got a bang out of this
- No spark on a 73 cutlass supreme! help!
- 1970 350
- some help with a situation
- Two barrel carb draining?
- intake manifold gasket problem
- Pulling the motor
- Let the tinkering begin...
- 350 rebuild
- 350 rocket rebuild
- 72 350 rocket rebuild
- converting pump to carb line with braided
- Just food for thought
- Silly mechanical fuel pump question
- new owner 72 442
