new cam / push rod question
Hey fellas, I'm confused about something. I have a fair understanding of camshaft geometry as far as lobe separation, duration, and height. But I see a lot of talk of folks needing shorter pushrods for their new cams. Doesn't this negate the effects of a taller lobe? Or is it because they bought too aggressive of a grind? Or maybe I actually don't understand camshaft geometry, which is entirely possible
Pushrod length has nothing to do with cam lift. All it does is correct rocker geometry so that the rocker tip correctly contacts the tip of the valve stem throughout the travel of the rocker. A cam with more lift causes the rocker to pivot through a larger arc, which means that the tip of the rocker travels inboard-outboard on the valve tip over a longer distance. If you simply increased cam lift and kept the pushrods the same, the rocker tip would be in the same place on the valve tip at zero lift, but then would be further outboard at max travel. Shortening the pushrod recenters the rocker tip over the total travel.
Now, this ASSUMES the two cams have the same base circle. Really high lift cams sometimes use a reduced base circle, since the maximum absolute lobe lift (dimension from the cam centerline to the tip of the lobe) is limited by the I.D. of the cam bearings (the lobes need to pass through the bearings. Reducing the base circle of the lobe increases total lift of the cam, but again screws up rocker geometry. This may require a LONGER pushrod to correct geometry.
In this scenario, is it correct to assume that the heads have adjustable rockers? What should/could be done with fixed height rockers? (yeah, I know, change 'em).
Oh sure, I shoulda' thought of that. So it's a ratio between base height and lobe height and where the arc centers, makes sense. And I hadn't thought about the limitations of the bearing ID.
Thanks Joe
Thanks Joe
I was looking at the paperwork and it doesn't say. Seems like it should but it doesn't. I wasn't too impressed by this shop. I'll call Monday and see if they keep records.
Nope. The correct pushrod length will allow fixed rockers to work just find. Adjustability is nice to accommodate variation in head gasket thickness, head milling, and valve stem height without resorting to different pushrods, but more often than not, the uninformed will simply crank the adjustment and screw up rocker contact pattern with the valve. If measured correctly, a custom pushrod will allow stock fixed rockers to work just find. Of course, getting custom pushrods every time is not practical, thus the preference for adjustable rockers.
Normally most aftermarket flat tappet cams with conservative lifts (.400-.500) will have similar base circles. There is normally some room between the diameter of the 4th cam journal (that's what dictates overall lobe size) and the top of the lobe so significantly reducing the base circle isn't necessary with conservative lifts. On a mild cam the base circle rarely varies more than .020 or so from stock. Remember even if you go from .400 to .480 valve lift you only need the lobe to grow .050 due the 1.6 rocker ratio.
I wasn't speaking about your work EFI, sorry if I gave that impression. I was speaking of the machine shop I took my heads to. They didn't even hot-tank the heads, just degreased them. They came highly recommended and it was essentially a large facility packed with heads and blocks so they are definitely used.
I'll try and call tomorrow and see if they have records about my millwork. Although it sounds like I most likely don't need to worry.
Originally Posted by jag1886 View Post
I don't claim to know a lot about cams but I know a lot of aftermarket cams are ground a smaller base circle, that could be one reason.
Please read my post above. A SMALLER base circle will usually require a LONGER pushrod to make up the difference, but the ultimate pushrod length depends on both base circle and total lobe height.
PICK PICK PICK
PICK PICK PICK
Along with other factors such as milling of deck and heads along with head gasket, valve stem height, etc. Bottom line; pushrods are relatively inexpensive. Assemble the engiine, then measure using an adjustable pushrod and order a set of the proper length. This isn't rocket science, it is how most engines are built.
rcdynamic88
Brakes/Hydraulic Systems
August 6th, 2014 07:41 PM
ggriffin1960
January 31st, 2012 10:20 AM
