Need help
Old Oct 25, 2013 | 07:02 AM
Alyani05's Avatar
Need help
Hi I'm new to this forums but I bought a 84 cutlass with a 72 olds 350 that had starter problems but fixed it. Last week I took it out to a car show in the mornin it ran fine all day till at night on the way back it started actin like it was runnin out of gas stopped at a gas station and pumped gas turned it on around 25-30 mph it did the same thing again so I pulled over and towed it home . The next mornin I notice the alt. belt fell off the bottom pulley but car still turns on thanks for any help
Old Oct 25, 2013 | 07:28 AM
I would guess that you had been running off the battery. I would reinstall the belt, charge the battery, and go from there.
Old Oct 25, 2013 | 04:30 PM
tru-blue 442's Avatar
Old School Olds
^^X2. She just ran out of electricity
from running the headlights at night
with no alternator.
Charge the battery as Eric suggests, and
you should be go to go.
Old Oct 27, 2013 | 03:56 PM
Alyani05's Avatar
Ok well I put everything back together and it started up fine got it on the road and did the same thing when it's warm it goes up to 35-40mph and when it get to normal operating temp it only gets up to 25-30 or before it goes into 2nd gear ........ I change the gas filter I'm think about the gas pump but i don't know any had this problem before ????
Old Oct 27, 2013 | 03:59 PM
RetroRanger's Avatar
72 Olds CS
Points or HEI?
Old Oct 27, 2013 | 04:03 PM
Alyani05's Avatar
I think it's hei
Old Oct 28, 2013 | 04:06 AM
Alyani05's Avatar
Ttt
Old Nov 10, 2013 | 06:56 AM
Alyani05's Avatar
Can anyone help ???wat other info u need
Old Nov 10, 2013 | 07:02 AM
So it's a shifting problem? It won't shift out of 1st until 35-40 mph?
Old Nov 10, 2013 | 07:39 AM
M-14's Avatar
Check the TV cable connection on the throttle linkage, this effects shifting.
Old Nov 10, 2013 | 08:20 AM
Alyani05's Avatar
It was shifting fine it's like I need more gas at 25-35 flat point
Old Nov 10, 2013 | 08:29 AM
Originally Posted by Alyani05
... when it's warm it goes up to 35-40mph and when it get to normal operating temp it only gets up to 25-30 or before it goes into 2nd gear ...
I think it's hei
So are you saying that when it's warmed up, it won't go any faster than 25 to 30mph, but other times it won't go faster than 35 to 40mph?
Or are you saying something else?
Does it ever go faster than 45mph? When? What happens when it does?
Does it have HEI or not?
Is English not your native language? If not, which language do you speak comprehensibly?
meoff
Site Help
Aug 29, 2013 12:15 PM
coppercutlass
Mar 1, 2013 07:33 AM
cutlassclay
May 11, 2012 06:31 AM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
